Graphisoft ID FAQ
Daniel Ferenc
What is Graphisoft IDArchicad authentication with Graphisoft IDManage Graphisoft IDManage CompanyManage LicensesPrivacy
What is Graphisoft ID? Graphisoft ID is your gateway to a great personal experience with all of the products and services we offer, including ArchicadBIMxBIMcloudLearn, and much more. In a world full of customer accounts, PINs, and passwords, we want to make your life a little simpler. With Graphisoft ID – your digital “master key” – you get easy access to our software and services. Graphisoft ID is a free account that you only need to create once. From then on, you can enjoy the benefits detailed in this article.
Where can I get support for Graphisoft ID? We wanted to cover all possible question related to Graphisoft ID in this article. Please click on the tabs above to find all the questions and answers. If you have any further questions, please contact your local Graphisoft support.
What are the benefits of authenticating Archicad using Graphisoft ID? Graphisoft ID is your gateway to a great personal experience with all of the products and services we offer, including ArchicadBIMxBIMcloudLearn, and much more. It also makes license management significantly simpler. Learn more about the benefits you can access with Graphisoft ID here. Graphisoft ID also helps us to provide you with more personalized support and content tailored to your specific needs, so you can get the most out of Archicad.
How can I authenticate Archicad 25 using my Graphisoft ID? Do one of the following:
  • At Archicad’s Startup screen: click the Sign-in button on the top right corner
  • Inside Archicad’s Work Environment:
    • Click the Graphisoft ID button at the lower right corner, or
    • Navigate to Help menu > choose Sign in
Then enter your Graphisoft ID’s credentials. Please read this article for more information.
Can I use one Graphisoft ID to authenticate multiple Archicad installations? Yes, one Graphisoft ID can authenticate multiple Archicad versions.
What if I don’t have internet access? If you don’t have internet access, or if signing in with your Graphisoft ID is not possible due to network restriction, it is not necessary to authenticate Archicad with your Graphisoft ID. Please refer to this article for more information.
What will happen if Archicad is not authenticated within 30 days? Once the 30-day sign-in period expired, file-saving and Teamwork function will not work. Archicad will run in Demo mode.
Does it apply to Trial and Education version? Yes, you should authenticate Archicad even with Trial or Education license if you are connected to the internet.
How does this work in a proxy or secure network? When Archicad determines Internet availability, it checks the exact same URLs and ports that will later be used for program authentication. If the connection to these endpoints is blocked, the authentication will not be enabled.
In case of large companies or schools/universities with many computers, how should we authenticate all Archicad installations? The Graphisoft ID represents an individual user. Therefore, each individual, using different user accounts on the same computer, should authenticate Archicad with his/her own Graphisoft ID credentials. There’s no need for the Company Admin to authenticate all of them. In a secure network environment, where the URLs and ports for authentication are not reachable, the authentication will not be enabled.
How do I create a Graphisoft ID?
  • If you have an existing account to MyArchicad, BIMx Model Transfer site, BIMcomponents,or Graphisoft.com, you already have a Graphisoft ID.
  • If you don't have a Graphisoft ID yet, you can create a new one using your email addresshere: http://graphisoftid.graphisoft.com/#/register.
  • Please note that License functions and applications also require you to use email andpassword.
What is graphisoftid.graphisoft.com used for? This is the portal for signing in and managing your Graphisoft ID. Here you can also create a new Graphisoft ID if you don’t have one. After signing in, you can change or edit your personal data. If you are an admin for a company, here you can also:
  • Manage company’s members (send invitations, approve requests and remove members).
  • Manage and assign licenses to different members.
  • Assign/transfer the Administrator role and Contract Manager role to any other member.
What is accounts.graphisoft.com used for? This is the new portal for users purchasing Subscriptions. It offers similar functions as the old website graphisoftid.graphisoft.com. If a Graphisoft ID account has access to Webshop for purchasing Subscriptions, it will always be automatically redirected from the old website to the new one. Currently, this website is only available to those who have Webshop access.
Is Graphisoft ID connected to the license or to the user? Graphisoft ID represents an individual user, it does not connect to the license. The licenses always belong to the Company.
I was not able to create a Graphisoft ID with my email address. What went wrong?
  1. Maybe there is an existing Graphisoft ID with the same email address. This can happen ifyou have previously created an account for MyArchicad.com, BIMcomponents.com, BIMx.graphisoft.com or graphisoft.com. When you type your email address in the Sign up form, the website will notify you if there is already an existing Graphisoft ID registered using this email address.
  2. Some email domain addresses are blocked because their registration process is not safe.You will not be able to create a Graphisoft ID with such an email address.
How can I find my Graphisoft ID if I don't remember it? Visit http://graphisoftid.graphisoft.com/#/resetpassword and type your email address
  • If the message "This email is not registered" appears, then your email is notassociated with an existing Graphisoft ID.
  • If the message does not appear, then the Graphisoft ID exists, and you can reset yourpassword by clicking "Send email".
I forgot my Graphisoft ID password. How can I reset it? Please visit http://graphisoftid.graphisoft.com/#/resetpassword and type your email address. You will receive a link to reset your password by email. Note:
I can't sign in to License Manager Tool or Graphisoft ID site with my email address and password. What's wrong?
  • Maybe you typed the wrong password. If you forgot your Graphisoft ID password, you canreset your password here: http://graphisoftid.graphisoft.com/#/resetpassword. After typein your email address and click Send email, a link to reset your password willbe sent to the given email address.
  • Maybe your password contains national characters which are not compatible with theLicense Manager Tool. Avoid using national characters (characters with an accent) inyour password:
  • Maybe you don't have a Graphisoft ID yet. Create one here: http://graphisoftid.graphisoft.com/#/register
When I try to sign in the “Your account has been blocked” warning appears. What's wrong? If you tried to log in too many times with the wrong password, your account is temporarily locked for 60 minutes. You’ll receive a notification email with a link. By clicking on that link can unlock your account.
Where can I change my email address or password for my Graphisoft ID?
  • If you signed up using an email address and password:
    • Sign in using graphisoftid.graphisoft.com and navigate to theChange email or Change Password sub-menus under thePersonal Details menu, or
    • Sign in using accounts.graphisoft.com, and click the button Change Email address or Change password under the Personal menu.
  • If you signed up using a social media account (Facebook/Google Account), you need toreset your password first using Forgot password function. After signing in, you can follow the same process above to change the email address or password of your Graphisoft ID.
Note: Sign in to http://graphisoftid.graphisoft.com to manage settings of your Graphisoft ID, like your contact preferences and your Company settings. You can also review here the online services you are registered for; and if your Graphisoft ID is connected to a Company, you can also view and manage the licenses your company owns.
How can I merge multiple Graphisoft IDs? Graphisoft IDs can not be merged. If you need to merge multiple Graphisoft IDs, please contact your local support to find the best possible solution.
How can I delete my Graphisoft ID? Via accounts.graphisoft.com, after signing in, under Personal menu, you can send a request to delete your Graphisoft ID by clicking Delete my account at the bottom of the page. You can also send a request to delete your Graphisoft ID and all marketing data related to it by sending an email to privacy@graphisoft.com
I already have an old Graphisoft ID from my study (or another office). Can I reuse it? Yes, as long as you still have access to the email attached to this Graphisoft ID. Make sure to change the email address connected to this Graphisoft ID before losing access to the email.
What if one employee left the company but wants to keep his/her Graphisoft ID, is it possible to change the email address of a Graphisoft ID? You can change the email address of a Graphisoft ID after signing in with your credential via:
What is a Company Graphisoft ID? How is it different from individual Graphisoft IDs? A Company Graphisoft ID is a Company's account in the Graphisoft ID system. The Company Graphisoft ID settings are an extension of the personal Graphisoft ID settings of individual users who belong to the Company. With the Company Graphisoft ID, Graphisoft customers are entitled to certain online resources that belong to the Company, not the individual user. For example, Archicad licenses (represented by soft or hardware protection keys) are always associated with a Company, not an individual. Similarly, Companies may have access to online services provided by Graphisoft, such as extra storage space on the BIMx transfer site or SSA-related local content. Put simply, in the Graphisoft world, the Archicad Protection Key(s) represent a Company, and the Graphisoft IDs represent individuals. When the two are "paired", a Company Graphisoft ID is created. From that point on, the individual becomes a member of the Company in the Graphisoft ID database. A Company Graphisoft ID has always at least one individual's "personal" Graphisoft ID associated with it. This member of the Company is called the "Administrator". Further individuals belonging to the same company may also join as standard members, using their own Graphisoft IDs. All members of the Company get access to the resources allocated to the Company, but only the Administrator has management control over the resources.
How can I know if my company already has a Graphisoft ID? If you have an existing account to MyARCHICAD, BIMx, BIMcomponents, or Graphisoft.com, you already have an individual Graphisoft ID. A Company Graphisoft ID is created automatically when the first person in a company associates their individual Graphisoft ID with any of the company’s Archicad Protection Keys through the “Key pairing” process. As the Administrator of the company, after signing in via graphisoftid.graphisoft.com, you will see the Company Details menu, where information about the company in the Graphisoft ID system is available. A Company cannot exist without a Graphisoft ID attached to it.
How can I create a Company Graphisoft ID? A Company Graphisoft ID is created automatically when the first person in a company associates their individual Graphisoft ID with any of the company's Archicad Protection Keys through the "Key pairing" process. The key pairing happens when:
  • You first publish a BIMx document from a commercially licensed Archicadusing your individual Graphisoft ID
  • You first download a commercial Software-Based Protection Key using your individual Graphisoft ID
  • If you have a hardware key, when you open the License Manager tool and sign in with yourGraphisoft ID for the first time, you can also create a company using the Authenticationkey. Please contact your local distributor for the Authentication key.
The first person who completes the Key Pairing process will become the Administrator. The Administrator can later transfer the administrator rights to another member.
How can I join a Company? There are two ways to join an existing Company:
  1. An Administrator can invite any individual with a personal Graphisoft ID to join theCompany he/she manages. The invited Member will receive an email with the invitation andcan accept or reject the invitation. The Administrator can send the invitation from:
  2. A Graphisoft ID user can send a join request to an Administrator at the first attempt ofusing Graphisoft's online services, e.g.:
    • Downloading a Software-Based Protection Key to his/her computer
    • Sharing a BIMx model
When an individual does any of the above actions using the Company's Archicad license and their own individual Graphisoft ID, then the administrator will be notified. At this point, this Graphisoft ID will become a Member of the Company.
What kinds of user roles exist in a Company Graphisoft ID? There are three types of user roles: Administrator, Contract Manager and Member. The person who creates the Company Graphisoft ID automatically becomes the Administrator. This role can be later transferred to any other member. A Company always has a single administrator and any number of ordinary members. The Administrator has certain privileges compared to regular members:
  • Members who join the Company have to be approved by the Administrator
  • The Administrator can eject members from the Company
  • If the Company has Software-based Protection Keys, then the Administrator can managethese licenses (see more under Managing Licenses)
  • The Administrator can transfer its administrative role to another member of the Company
The Contract Manager is the one who purchases and manages the Subscription. He/she can upgrade/downgrade, extend or cancel the Subscription.
How can I access the Company Graphisoft ID settings? Once you have joined a Company, the Company information will be accessible when you log in to your own Graphisoft ID under graphisoftid.graphisoft.com or accounts.graphisoft.com. Ordinary Members will only be able to see the information about the Company they are joined to, and the software licenses (protection keys) available to them. Only the Administrator has the right to manage these resources.
How can a Company change who is the Administrator? The first member who joins the Company automatically becomes the Administrator. Only the Administrator can transfer Administrator rights to another Member. To transfer your Administrator status to another member, please follow the guide here.
How can I leave a Company to join another one? To join a new Company, first you need to leave the current one by: Once your Graphisoft ID has been disconnected from a Company, you are free to join another Company, using the same Graphisoft ID. Note: an Administrator can only leave the company after giving the Administrator role to another Member.
How can I remove a user from my Company? As a Company Administrator, you can disconnect a user from the Company.
  • Using graphisoftid.graphisoft.com: open Company details > Members sub-menu. Press the Disconnect button next to a Member you want to remove.
  • Using accounts.graphisoft.com: open the Company menu. Under Company Members section, press the Disconnect button next to a Member you want to remove.
Should we use one Graphisoft ID for the whole company? It depends on the company size and how the company manages its licenses. For example, in small firms where no strict rules are needed to limit access to software licenses, all users can manage licenses using a single, shared Graphisoft ID with Administrator privileges. Having one Graphisoft ID for the whole company also simplifies the onboarding process for new members.
What are the benefits of having an individual Graphisoft ID for each user?
  • It’s easier to manage license access if there are many single Software licenses in theCompany pool. We can either assign license usage for a specific user, or use the Companylog to know who downloads which license.
  • It provides better security, as the Administrator account is managed by a dedicatedperson.
  • Each user can use their own Graphisoft IDs for multiple Graphisoft websites (graphisoft.com, MyArchicad.com, BIMcomponents.com, BIMx.graphisoft.com)
Who should be the Administrator? A Company Administrator is responsible for inviting, accepting, or disconnecting members. He/she can also control the Software license access by giving permission to certain members of the company. This person can be the head of the company, or a dedicated IT technician.
Who should be the Contract Manager Contract Manager is the one who manages the Subscription purchase, upgrade/downgrade or cancellation. Thus, this person can be the same as the Company Administrator, or this can be a separate person from company’s financial department. When a person purchases BIMcloud SaaS for the first time, this person will become the Administrator, Contract Manager and BIMcloud Server Admin of the newly created company.
Where can I see which role do I have in the Company?
  • Using graphisoftid.graphisoft.com: after signing in with your Graphisoft ID, open the License pool menu. At the top, you can see your given role in the Company.
  • Using accounts.graphisoft.com: after signing in with your Graphisoft ID, open the Company tab. At the top, you can see your given role in the Company.
How can I change my role? Only the Administrator can change the role of each member in a Company. If you, as an Administrator, want to give your role to another member, please follow the guide here.
What is a Software-Based Protection Key? Graphisoft provides the CodeMeter protection key (developed by WIBU) from Archicad 13. The CodeMeter Hardware and Software-based Protection Keys represent your license to use ARCHICAD. A Software-based Protection Key has the same functionality as Hardware-Based Protection Keys, but instead of storing software licenses on a USB stick, the licenses are stored in a software container file on your computer. When you buy a Software-Based Protection Key, it becomes available to you in your Company License Pool — an online repository where you can access all of your purchased Software Keys. You can download the Soft Licenses to your computer with the License Manager Tool.
What is a Company License Pool? Company License Pool is the online repository of all the Software-Based Protection Keys and Hardware-Based Protection Keys that a Company owns. This inventory can be managed by the Company Administrator, if the Company has a Company Graphisoft ID. (See How can I create a Company Graphisoft ID?)
How can I access the Company License Pool? The online Company License Pool is accessible from the Graphisoft ID website (graphisoftid.graphisoft.com or accounts.graphisoft.com), for users who joined a Company (see How can I join a Company?). If your personal Graphisoft ID is associated with a Company, you can see the License Pool menu item when you log in with your Graphisoft ID. If you are the Company Administrator (learn more about Company roles), here you can see all Protection Keys your company owns. If you have Software-Based Protection Keys, you can manage those keys here, e.g. you can control who can use a specific Software-Based Protection Key.
I cannot see the You probably haven't joined a Company yet using your Graphisoft ID. See how you can join a Company.
How can I move Software-Based Protection Keys between computers? If you want to transfer a Software-Based Protection Key from one computer to another, you can use the License Manager Tool to upload the Software-Based Protection Key to the Company License Pool. Then, you can download the Key to a different computer. You can do this as many times as you want.
How are Software-Based Protection Keys updated when a new Archicad version is released? Software-Based Protection Keys in the License Pool are updated automatically. In contrast, Software-Based Protection Keys that are downloaded to a computer at the time of the release must be updated using the License Manager Tool. Start the License Manager Tool on the computer where the License is downloaded, and follow the instructions.
Can one key exist in two different company pools? No. Archicad Protection Key(s) represent a Company, thus it cannot exist in two different Company pools.
My Company owns Software-Based Protection Keys, yet I can’t see any in the “License Pool”. What’s wrong? If you are not the Administrator of the Company, you can see only the Software-Based Protection Keys that were made available to you by the Administrator: either assigned to you specifically or set to “Available For: Everyone”. Ask the Administrator to assign a key to you.
Who is the Company Administrator? The Company Administrator has elevated permissions to manage the Software-Based Protection Keys of the Company. See more under „What kinds of user roles exist in a Company Graphisoft ID?” If you are not sure who your Company Administrator is, you can find this information under “Company Details” on the graphisoftid website.
What information is available about Software-Based Protection Keys in the Company License Pool? The information available for you about the Company License Pool and its available functions depends on whether you are an Administrator or a Member on the Graphisoft ID site.
  • Protection Key ID: Identification of the protection key whichcontains the purchased license(s)
  • Products: name and quantity of the products included in the key
  • Available for: Company Administrator can define which SoftwareKeys should be assigned to particular users in your company
  • Downloaded by: Here you can see who downloaded the Software Key tohis/her computer
  • Programmed to: Name of the computer where the Software Key isprogrammed at this moment
  • SSA status: This parameter shows whether the selected Software Keyis on SSA (Software Service Agreement)
As a member, you can only see the Software-Based Protection Keys that were made available to you by the Administrator: either assigned to you specifically or set to “Available For: Everyone”. Ask the Administrator to assign a key to you.
What is the best practice for companies to manage their licenses? Loose scenario: for small firms where no strict rules are needed to limit access to software licenses Recommendation: All users are allowed to manage licenses using a single, shared Graphisoft ID with Administrator privileges.
  • All employees and managers use the same Administrator Graphisoft ID to sign in to theGraphisoft ID website and the License Manager Tool.
  • The Software-Based Protection Key(s) are set to: ”Available for: Admin only”
  • Users can download any Software Keys from the Company License Pool to their computersusing the License Manager Tool.
Normal scenario: for medium-sized firms, where licenses are managed by an Administrator, but users have free access to company resources Recommendation: Two levels of Graphisoft ID access: Administrator and Members (each employee has her own Graphisoft ID).
  • Multi-license (NET) key is managed by the Administrator. Key is set to ”Available for:Admin only”. Administrator installs the NET Software-Based Protection Key to centrallicense server computer
  • Single licenses are set to ”Available for: Everyone”. Members of the Company can freelydownload single licenses to their computers using their personal Graphisoft ID.
Strict scenario: for large firms, where licenses are strictly issued by an Administrator, and the management does not want individual users to manage the NET key(s). Recommendation: Two levels of Graphisoft ID access: Administrator and Members (each employee has her own Graphisoft ID).
  • Single licenses are set to ”Available for: [named user]”. Members of the Company canonly download single licenses specifically assigned to their Graphisoft ID.
As a freelance architect, how can I access multiple License Pools with one Graphisoft ID? One Graphisoft ID can only access one License Pool by joining one Company. It is not possible to access multiple License Pools with one Graphisoft ID. In case you are a freelance architect, you can still be able to get a license from different companies, through floating Hardware or Software NET keys in the company's local network, or by borrowing a license from the company.
Is an individual Graphisoft ID connected to a license? No, the license always belongs to the License Pool of the Company.
How do we prevent users from downloading additional licenses? From the graphisoftid.graphisoft.com and accounts.graphisoft.com website, you can assign single licenses for specific users based on individual Graphisoft ID. Then the members can only download the licenses specifically assigned to their Graphisoft ID.
I signed in with my Graphisoft ID when I start Archicad. Will this be connected to the Company pool? If you are not yet a member of the Company, signing in with your Graphisoft ID in Archicad will not connect your Graphisoft ID to the Company Pool. To do so, you need to be invited to the company. Please see How can I join a Company? If you are already a member of a Company, when you start Archicad:
  • If you don't have a license, Archicad will automatically download a Software-basedProtection Key available to you from the Company Pool.
  • If you already have a license (either a Hardware key, a NET license from the company's network, or a Borrowed license), Archicad will start with the current license instead.
Does Graphisoft collect personal data? Yes, Graphisoft collects and stores certain type of data when you are using our services. How and where the data is collected can be found here.
Is Graphisoft compliant with GDPR? Yes, we are compliant with GDPR. The Privacy Policy includes more information about how we comply with GDPR.
What data connected to Graphisoft ID is collected when using Archicad? When you sign in with your Graphisoft ID in Archicad, we might receive the following information:
  • End-user login information
  • Archicad edition, version, build number and language
  • Operating System
  • License type
  • Unique Computer ID
Where is this data stored? Your personal information and data files are stored on Graphisoft’s servers and the servers of companies we hire to provide services to us. Your personal information may be transferred across national borders because we have servers located worldwide, and the companies we hire to help us run our business are located in different countries around the world. For more information about Privacy Policy, please read here.
How can I request Graphisoft to delete all personal data about me? You can send a request to delete your Graphisoft ID and all marketing data related to it by sending an email to privacy@graphisoft.com
Browse more articles
Back to articles
