Setup & License articles
Articles
License Pooling
What is a License Pooling? License pooling (aka Floating licensing or Network licensing) is a software licensing option available for customers with NET licenses, allowing several users on the same TCP/IP network to share access to product licenses p...
BIMcloud as a Service Connection Test
BIMcloud as a Service enables real-time, secure teamwork between architects in the cloud. With your BIMcloud as a Service subscription, you get access to your own private BIMcloud server hosted by Graphisoft in the Google Cloud Platform. No IT setup ...
How to Open and Forward Ports on Your Router
If you consider hosting your BIMcloud for external connection as well, you need to make sure to set the environment to fulfill some requirements. One of them is to make it possible for Archicad client computers to access certain ports on the server c...
Getting Started with Graphisoft BIMcloud Basic
Related versions: BIMcloud Basic 2018.2 and newer This article will guide you through the BIMcloud Basic installation and configuration step by step with some additional information. Before Installing Checklist for installing BIMcloud Basic in the lo...
wp-content_uploads_2019_03_bcb_install_1_m.png wp-content_uploads_2019_03_bcb_install_2.png wp-content_uploads_2019_03_bcb_install_3.png wp-content_uploads_2019_03_bcb_install_4.png
Top Contributors
