Setup & License articles
Articles
Windows XP
GRAPHISOFT supports only "Professional" Edition officially, and none of the ARCHICADs were tested by GRAPHISOFT on "Home" Edition. However, since the two editions only differ in their feature set ("Professional" edition has additional features, e.g. ...
automata by Graphisoft
  • 2 Views
  • 0 comments
  • 0 likes
Questions and Answers about 64-bit
What does "64-bit" mean? A 64-bit computer, operating system, or software application is able to use 64-bit wide memory addresses, while a "traditional" 32-bit computer, OS or software can only use 32-bit wide memory addresses. The maximum memory add...
gkmethy by Graphisoft
  • 23 Views
  • 0 comments
  • 0 likes
Windows XP and 32-bit Support
ARCHICAD 16 is the last release of ARCHICAD to support Windows XP and any 32-bit operating system. The next major release of ARCHICAD will be 64-bit only, and will support only 64-bit Operating Systems, including Windows 7 and Windows 8. What does th...
  • 64 Views
  • 0 comments
  • 0 likes
Troubleshoot hotfix installation problems
Troubleshoot permission problems on Mac Issue: The installer of the Hotfix gives Archicad ## Hotfix ## cannot access one or more files/folder in message. Solution: As a first step make sure that you are logged in as an administrator user. In System ...
WIBU Key not found for ARCHICAD 7, 8 and 9
Issue On OS X 10.6 Launching AC 7, 8, or 9 Warning message appears, "No WIBU-KEY driver found. (501)”, ARCHICAD cannot be launched. Cause Wibu key driver 6.00e was installed on that machine during the installation of ARCHICAD 16. This driver cannot r...
  • 9 Views
  • 0 comments
  • 0 likes
Rosetta
Rosetta is an emulated environment in Mac OS X that enables running applications compiled for PowerPC processors on newer Macs that use Intel processors. ARCHICAD 13 - ARCHICAD 13 and over are only available for Intel-based Macs. See the complete ARC...
  • 7 Views
  • 0 comments
  • 0 likes
Limitation Of Ports That Wibu Scans
KarlOttenstein's tip on using the WIBU -Key Control Panel! "(...) The sometimes considerable delay while ARCHICAD is starting is actually the WIBU protection key driver searching all ports for the key. You can change things so that only the proper po...
  • 7 Views
  • 0 comments
  • 0 likes
Intel Mac platform
"MacTel" refers to the Intel-powered Macintosh platform. Apple abandoned the previously used PowerPC processors in favor of the Intel chips in 2006. This new platform also requires software vendors to release a new version of their products that run ...
  • 2 Views
  • 0 comments
  • 0 likes
Top Contributors
