2d antialiasing in Archicad 22 and 2d navigation speed.
As you can see at the image 2d antialiasing in 22 version is worse then in 21
Image was taken by screen shots in the same conditions in the programs and the default settings for nvidia GTX 970m.
Besides. The 2d navigation speed IN LAYOUTS on heavy drawings in 22 version has become less! Is it because of the preparation for the sooth zoom effect each time i touch the scroll??
This two problems are very bad for me...
I also found that the CPU load of the graphics card jumps to 100% precisely when zooming. It would be great if the navigation was faster. It turns out that the system resources are used for non-critical pop improvement.......
Can i turn of the smooth zoom effect? In the registry?
MSI GT72 6QD with windows 10.
1 REPLY 1
The problem with antialiasing is in "Do not antialias horizontal and vertical lines" feature. AA works good if it switched off
