Installation & update
3D Object Preview not visible/ blank white
When I select on the arrow or simply double-click to edit the Stairs [through Stairs Tool], the favorites or previews are not visible. Are files missing? Or is it something that can be toggled? Because I'm pretty sure I've clicked on Front/ 3D View and it was still blank/ white. The only thing that is visible is some details with [Preview Image] options.
I need help,
thank you!
I think this has been mentioned before.
Try updating your video drivers.
Once again, saved my day.
Thank you so much Barry!
