3D Walkthrough mode
In AC 21 and 22 when in 3d walkthrough mode the direction arrows have stopped working, has anyone else experience this, and if so how can I correct this?
If you do a New & Reset and start a brand-new project based on the default Template, do they work?
I am trying to figure out if this is a file-specific problem or not.
4 REPLIES 4
Thanks, I did a reset and started the programme again and the problem seems to have resolved itself. It must have been a glitch!
Greg D
I have run into the same issue (v22). This new problem showed up today on a two-year-old project. How does one go about saving the project while resetting to gain arrow navigation back?
Greg Danskin - Architect
http://www.danskinarchitecture.com
AC 19/20/21
iMac Retina 5K, 4 GHz Intel Core i7, 32 GB 1867 MHz DDR3, AMD Radeon R9 M395X 4096 MB
OS 10.13.4 High Sierra
Greg D
I closed all programs and restarted the iMac, and it seems to have cleared it up. It was affecting all the project in AC 22.
AC 19/20/21
