3D not showing
Need urgent help !! My 3D doesn't show anymore.
The model exists, the elements are there because I can select them, move them and do all the setiting on them in 3D window, but they are masked/ invisible. The 3D screen is completely blank.
I tried to select one element in the plan and isolate it in 3D window, it does show up, but when I hit the shortcut to visualize the entire model, then it turns invisible. The problem is only with this project. I opened other projects and they works just fine.
Plans, sections and façade work properly.
I checked 3D styles, Graphic substitutions, Layer combinations, Views options, Renovation filter, etc. nothing seems to work.
Thanks for helping me out to get back my 3D.
10 REPLIES 10
Maybe you have something very far away from your main model.
It could be very far away in height which is why you may not notice it in plan view.
