Setup & License forum
4K Screen/Monitor Settings
SergeA
I don't seem to find a solution to my issue.
When I changed the laptop, like two years ago, drawing straight lines, walls, etc. becomes increasingly complicated on a 4K monitor. I tried to change the Cursor snapping range from 5 to 3 but it still doesn't work well.
Has anyone experienced the same issue? What was the solution or workaround?
Best
If I worked at a 4K resolution, I would increase the Cursor Snapping range, not decrease it. To 7 or 9 pixels. That means that if the cursor is 7/9 pixels aways from a point or edge, it will find it and the Cursor shape will give the proper feedback. A Cursor Snap range of 3 means you have to move your cursor very very close for it to find those points or edges.
Laszlo Nagy, Lead Moderator, Community Admin
Get Archicad Tips at https://twitter.com/laszlonagy
AMD Ryzen 1700X CPU, 48 GB RAM, Nvidia GTX 1060 6GB, 500 GB NVMe SSD
2x28" (2560x1440), WIN10 PRO ENG, AC20-AC25
Loving Archicad since 1995
1 REPLY 1
