2003-12-29 10:35 AM
2003-12-30 02:36 AM
TRIBU wrote:We are not losing anything.
I have just found that it is virtually impossible to export 8.1 file to any of the previous versions, ..
2003-12-30 05:16 AM
Jacek wrote:Is the problem saving a file or an archive?TRIBU wrote:We are not losing anything.
You have an option to Save As and at the bottom of the window tick the marker to expose a whole range of options, including: 8.0, 7.0 6.5 etc...
2003-12-30 10:38 AM
2003-12-30 12:10 PM
TRIBU wrote:Well, as the PLA contains all the library parts, which are not backwards compatible, I don't see a way to do it, except to save the file to whatever old version is needed, open it in that version, and load the approapriate library, and THEN archive.
It is .PLA Archive problem.
2004-01-09 02:21 PM
2004-01-09 09:18 PM
YA.H.VE wrote:You do. If you did not wipe the 6.5 7 etc off, they are still where you originally installed them and the file should know where - that is, if you have not moved them around.
My problem is similar. I switch to AC8.1 and now I don't have the old libraries.
2004-01-09 10:01 PM
2004-01-09 10:43 PM
