2003-11-19 05:13 PM - last edited a month ago by Aruzhan Ilaikova
2003-11-19 05:46 PM
2003-11-19 06:56 PM
~/archiben wrote:Thanks, Ben
are you sure youinstalledthe library? you didn't choose a custom installation and not check the box to install the library?
you could check that the "ArchiCAD Library 8.1" has been installed in the "ArchiCAD 8.1 folder" inside your applications folder. if it's not there, perform another custom installation from the CD choosing only the library to be installed . . .
~/archiben
2003-11-20 02:09 PM
Darryl wrote:Be sure to start with the default settings. If anything is NOT loaded, the Report window should come up. Open the library manager. See what is loaded under Local/LAN tab - should be three folders and the library PLA.
New install on OSX.2.8. Upon first launch and creating new project (default settings) I do not have complete libraries—no doors or windows for example. I have tried opening an 8.0 file with attendent libraries, and still same effect.What am I doing wrong?Thanks for any vector!
2003-11-20 03:30 PM
Djordje wrote:Be sure to start with the default settings. If anything is NOT loaded, the Report window should come up. Open the library manager. See what is loaded under Local/LAN tab - should be three folders and the library PLA.Darryl wrote:
