Installation & update
8.1 on windows XP home edition
technical requirements state that you need winXP pro to run AC8.1
has anyone tried it on winXP home edition? i've got the edu version.
-juri
5 REPLIES 5
Djordje
Ace
juri wrote:
technical requirements state that you need winXP pro to run AC8.1 has anyone tried it on winXP home edition? i've got the edu version.
Full INT running OK here ...
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Eduardo Rolon
Most of my students run it on Xp Home with no problems
Eduardo Rolón AIA NCARB
AC27 US/INT -> AC08
another Moderator
my computer is window XP home edition, and it work pretty well.
Just the Bug problem never stop. It bother me a lot
I have AC8.1 at home using WinXP home edition. Works fine for me, I have also used AC 6.5, AC 7.0 student version on my computer and never really had any problems. You might want to check what service pack you have for WinXP. You might have a conflick with other software on your computer. WinXP update is located here http://v4.windowsupdate.microsoft.com/en/default.asp
The program was not officially tested on Win XR Home, only on Win XP Professional. This is why it says in the documentation that Win XP Pro is the required operating system (or Win 2000). Maybe Microsoft can answer whether there is any big difference in the two versions that may cause a problem.
Laszlo
