Installation & update
AC 10.815 bug / 2D content is lost in section/elevations
SUMMARY
2D content is sometimes lost in sections/elevations
DESCRIPTION
2D content is sometime lost in sections/elevations.
To me this (only … ?) happens when publishing sections to DWG. All 2D content is sometimes lost / deleted in ArchiCAD in some section/elevations. The model is also "deleted" but reappears after regenerating from model. No clear system here... Sometimes AC will also crash. (3 times today trying to figure out this.)
I might be related to 2D fills.
1) I published a section. 2D content (and model) was lost from section in AC (and of course also in the DWG file).
2) I recreated the 2D stuff (which I in this case had copied to the clipboard) but deleting all fills.
3) New publish went painless.
4) But ….. Putting in the fills again, - a publishing again (with fills) also went painless. As a said, - no system
REPRODUCED
No problem on my system ….
SOLUTION
Stay with AC 9?
None
SYSTEM
ArchiCAD 10 build 815 INT on Win XP Pro sp2
AMD Athlon 64 X2 4400+, 2DB RAM
ATI Radeon X1800 with dual DELL 24" LCD
2 REPLIES 2
TomWaltz
AC9 had that problem too, (As did 8.1 and 8 ). So much for it being fixed in AC10...
Tom Waltz
Sorry to say but this has not been fixed in R10 build 987.
I may be related to having sections set to manual-rebuild and drawing in layout to manual update. (But even after rebuilding section and refresh layout) the 2D content disappears in some sections when publishing to DWG
PLEASE FIX NOW.
Learn and get certified!
