Setup & License forum
AC 13 64bit and Windows 7 Pro 64 bit
ArchiCad 13 64 bit to run under Windows 7 Pro 64 bit workstation: Question -- will it? Tried and tested anyone? So far happy with AC13 under Windows XP Pro 64 bit but would like to upgrade to W7/64 for general reasons.
6 REPLIES 6
Works fine for me. Both booted native and in VM.
Work fine for me too - W7x64 = speed and bigger memory acces .
the only problem is to find 64bit drivers for your hardware because x64 accept only verified drivers or by bypass this verification using software like dseo (Driver Signature Enforcement Override) at
http://www.ngohq.com/home.php?page=dseo
Hello Mathew, thanks for the green light.
Thanks Archibaldo - two users giving me a 'green light' gives real confidence for the system upgrade.
KeesW
Mike
I've been using 64 bit OS with Archicad for over 4 years and have found no problems at all. Current configuation uses it with Win 7 and that is also trouble free.
Cornelis (Kees) Wegman
cornelis wegman architects
AC 13 demo and windows 7 64bit - not working for me. AC loading for ever.
After installation there is no archicad.exe file - trying to repair fixed the problem. But still not working. I have JAVA 64bit - probably this is the problem
