Installation & update
AC13 empty install wizard
Im trying to install AC13 on windows 7 but Install Wizard displays an empty frame when license agreement or the install options should be displayed. Tried updating the video driver but that made no difference.
Problem is briefly mentioned here:
http://www.archicadwiki.com/ArchiCAD%2013%20Install%20Problems#Installer_wizard_displays_empty_scree...
3 REPLIES 3
hi,
i have the same problem..I also installed the video card driver but I have not solved the problem.....how you solved this problem?
thank's
Raffaele
I didn`t .. just installed same iso on my other pc which has XP on it.
So the problem exists .. im still waiting for the answer.
I'd suggest trying it again with Aero Desktop turned off, it seems to be causing some quirky behaviours with various graphical applications and it's specific to Windows 7 so it's a plausible culprit.
Here is a link to the instructions on to turn it off. Please let me know if it works.
http://www.howtogeek.com/howto/windows-vista/disable-aero-on-windows-vista/
Learn and get certified!
