Setup & License forum
AC14 does not work in Terminal server (it worked in 13, 12)
Arch Willingham
I have installed, uninstalled, reinstalled, etc AC14 in terminal server but it will not recognize the network key. I can run the Wibu key utility on the terminal server and it works (and finds the network keys). It worked on the same machines (s) fine with version 13.
Help!!!
Thanks!
Arch
Arch Willingham
Have you upgraded the network key through the Graphisoft upgrade website?
Versions 6.5 to 25
Arch Willingham
That was the first thing I did when I got the new software. I can use AC14 on the normal workstations just fine.
Arch Willingham
