Hi everyone - Anyone experiencing this?
I'm working on a MacBook Pro [10.15.4] with AC22 in teamwork and have recently opened several teamwork files where some windows won't show anything at all. They simply open as completely blank - though it seems I can select things without seeing them or any of the highlighted nodes. Sometimes it's only the layout window or master layout that appears completely and sometimes it includes all windows - even the Plan View.
Attached is a screen grab of the a Master Layout that is zoomed to extents with everything in the window selected.
From that 2.3% zooming value visible on your Options Bar I would say you are pretty zoomed in.
What happens if you right-click into the gray background and choose the "Fit in Window" command from the context menu?
Loving Archicad since 1995 - Find Archicad Tips at x.com/laszlonagy AMD Ryzen9 5900X CPU, 64 GB RAM 3600 MHz, Nvidia GTX 1060 6GB, 500 GB NVMe SSD 2x28" (2560x1440), Windows 10 PRO ENG, Ac20-Ac27
Noted - however here is an image of the same layout at only 2% in a file where it is working - still quite visible. Also note despite 59 items being selected with the arrow tool in the current view, no nodes of the selected items appeared.
