Hola,
I have removed your other thread because it is a copy of this one, please do not create duplicates.
Taking a guess at your problem you might need to verify your Video Card drivers since they are usually the ones that cause problems in Windows if they are up to date then you might need to check your java settings.
If none of those work you might need to contact your reseller for more help. Your problem seems particular to your setup since there are no other window users reporting the same problems in the forums.
eduardo rolón AIA NCARB
Another of the forum moderators.
Macbook Pro M1 Max 64GB ram
OS X 10.XX latest
AC25 US/INT -> AC08
Vectorworks 2022
