2022-01-08 06:16 PM
Hi friends,
I just installed Archicad on my MacBook Pro. One odd bug that is immediately apparent is that finder windows are comically wide. I've attached a video showing the window, and how I cannot adjust its width. The height can be adjusted, just not the width. Is this a bug?
Thanks,
Benjamin
Solved! Go to Solution.
2022-01-08 07:09 PM
Known Bug.
See here for work arounds:
https://community.graphisoft.com/t5/Setup-License-articles/MacOS-12-Monterey/ta-p/309154
2022-01-08 08:04 PM
Thank you Eduardo! What a strange bug, and a stranger way to fix it, but it did work.
2022-01-21 01:17 PM
I have this problem too!!! What is that solution? 😰
i use macbook pro 2019
i9 - ram 16
and Monterey mac os version
2022-01-21 01:50 PM
Follow the link in the above post for the workaround. Final solution should arrive in a future update.
2023-03-09 02:50 PM
I have the same problem
2023-03-09 06:55 PM
Update your software.
