Setup & License forum
Absurdly wide Finder Window when opening a file.
Hi friends,
I just installed Archicad on my MacBook Pro. One odd bug that is immediately apparent is that finder windows are comically wide. I've attached a video showing the window, and how I cannot adjust its width. The height can be adjusted, just not the width. Is this a bug?
Thanks,
Benjamin
1 ACCEPTED SOLUTION
Solution
Eduardo Rolon
Known Bug.
See here for work arounds:
https://community.graphisoft.com/t5/Setup-License-articles/MacOS-12-Monterey/ta-p/309154
eduardo rolón AIA NCARB
Another of the forum moderators.
Macbook Pro 2.4 i9 32GB ram
OS X 10.XX latest
AC25 US/INT -> AC08
4 REPLIES 4
Solution
Eduardo Rolon
Known Bug.
OS X 10.XX latest
AC25 US/INT -> AC08
Thank you Eduardo! What a strange bug, and a stranger way to fix it, but it did work.
Mohamadbaqeri
I have this problem too!!! What is that solution? 😰
i use macbook pro 2019
i9 - ram 16
and Monterey mac os version
Follow the link in the above post for the workaround. Final solution should arrive in a future update.
OS X 10.XX latest
AC25 US/INT -> AC08
