Doesn't stop the prompts though.
In the past (pre-Mavericks), you wouldn't be asked again. The problem then, was that all versions of AC were just called "ArchiCAD" - so if you launched Archicad 15 and then 16 - you would be prompted by the firewall because it would detect that the Archicad.app for 16 was different from the one previously 'approved' for 15 (etc).
Not, Graphisoft has named the app Archicad 17.app so it can have its own entry in the firewall table. But, even with it there, the firewall prompt for AC (as well as QT) happens on every launch. I have to assume that this is an Apple issue with Mavericks and not a GS one, but don't know... since Ted is on Mountain Lion, this may be a GS issue after all...
One of the forum moderators
AC 27 USA and earlier • macOS Ventura 13.6.6, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
