“Apply Data is missing”
Archicad 24 USA is giving this notice on opening, after installation of macOS 10.15 Catalina. I can find no “Apply Data” file.
Minh Nguyen
Dear Ignacio,
Thank you for the report and I am very sorry for the issue!
I believe the machine was upgraded to Catalina, then the error starts to appear, is that correct?
Unfortunately, we have never encountered this error before. I'm wondering whether this happens immediately after starting Archicad 24, or do you need to start a new file/open an existing file for it to happen?
Have you tried to reinstall Archicad also?
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
There was such an issue before with Archicad years ago, which seem to have been fixed by reinstalling it:
https://archicad-talk.graphisoft.com/viewtopic.php?t=49243
Thanks.
It must be the application name change. I couldn't give Full Disk Access permissions to both USA and INT versions with both named Archicad.app. The whole experience was so painful that I don't think I want to try restoring their names, at least until I have a lot of time to spend on this without again hurting work schedules.
