Installation & update
ArchiCAD 21 Crashes
Roopa A
When I tried to open AC 21 , and uses the Work environment it crashes.. When I use any of the tools from menu bar, It crashes.
What is the issue? Do I have to reinstall the software or how?
Can anyone help me to fix this. Please.
Thank You,
Regards,
Roopa A
Roopa A S
5 REPLIES 5
Right before the crashes and issues started happening, did you change something in your operating-system? Maybe install a system update? Update your graphics card? Etc.?
I suppose something must have changed that started causing these issues.
See also string "ARCHICAD 21 CRASHES AGAIN AND AGAIN DURING 2D DRAWING ON ELEVATIONS."
It's new and it's B A D.
Eduardo Rolon
krysmark,
Is yours crashing in the same way or is it a different issue? If it is different then keep it within that particular post and do not double post because it will be more difficult for users to help you.
That being said, I'll be giving suggestions on the other post.
Eduardo Rolón AIA NCARB
AC27 US/INT -> AC08
another Moderator
Those crashes seem to similar, or related and happened around the same time. If anything, i suggest to combine those treads.
The main problem is, I don't seem to find a sensible pattern/reason yet, despite a fact that i worked in ArchiCad since early 90's and using computers since +/- 82 - it's bad... .
Could you post the Bug ID that is visible in your screenshots? Guys at GS HQ would like to know.
