Installation & update
SOLVED!
ArchiCAD mouse pointer insanely small Windows 10
Paul King
Is anyone else finding that on a 4K screen, following the recent Windows 10 Creators update, that the ArchiCAD mouse pointer is now insanely small? (for all ArchiCAD versions)
ArchiCAD is the only application so affected, and while increasing windows UI scaling, and increasing windows mouse pointer size to maximum within Windows Control Panel generallyworks as expected for everything else, the mouse pointer once moved over the ArchiCAD application window) becomes so tiny it is barely visible - and certainly the ArchiCAD dynamic pointer style context feedback is utterly undetectable.
This seems to stem from ArchiCAD's non compliant method of handling the custom mouse pointer DPI scaling rather than anything with the OS - as is demonstrated by nearly ALL other applications that predate the windows update being unaffected. (perhaps a compromise or carry over from the way custom mouse feedback is implemented for the Mac platform?)
Rolling back to or reinstalling an earlier version of Windows 10 are not good options in my case.
What have others done to solve this serious problem?
PAUL KING | https://www.prime.net.nz
ArchiCAD 8-27 | Twinmotion 2023
Windoze 11 PC | Intel Core i9 10900K | Nvidia Gforce RTX 3080 | 32 Gb DDR3 | 2x4K monitor extended desktop
1 ACCEPTED SOLUTION
Solution
Daniel Kovacs
Graphisoft Alumni
Graphisoft Alumni
Paul wrote:
Looks like that update for AC20 last year never happened, which means I am pretty much crippled on projects still running under AC20. When will AC20 realistically be patched with a windows 10 Creators update DPI fix now?
Yeah, the ARCHICAD 20 7001 update got a little bit delayed (was stuck in preview phase), but last week it was publicly released. You can download it from here!
Regards,
Daniel Alexander Kovacs
GRAPHISOFT
25 REPLIES 25
Ralph Wessel
Mentor
Yep, same problem here.
Ralph Wessel BArch
Do you have the latest AC21 update, build 4004, installed?
In the list of fixes I read this:
230368 USER INTERFACE: For Ultra High Definition (4K) screens, mouse cursor appeared small inside ARCHICAD in Windows 10 with Display Scaling enabled.
http://www.graphisoft.com/downloads/archicad/updates/AC21/AC21-3005to4004-ReleaseNotes.html
http://www.graphisoft.com/downloads/archicad/updates/AC21/ImprovementsList.html#4004
Paul King
Thanks Lazlo - that update looks hopeful. Not yet tested or released for New Zealand I see.
I would update with the preview version now anyway (a great idea making these available!), but have BIMserver & other users to consider.
In the meantime, is there a way that Windows 10 can actually have display scaling disabled? (since as described that appears to be a requirement for the bug to manifest)
I have not found a setting that makes any difference in Windows control panel or via application compatibility settings
Ticking the 'disable display scaling on high DPI settings' option in ArchiCAD properties/compatibility settings menu does nothing for example.
Paul King
Just tested the 4004 update, and sadly no immediate improvement at all to issue "230368 USER INTERFACE: For Ultra High Definition (4K) screens, mouse cursor appeared small inside ARCHICAD in Windows 10 with Display Scaling enabled."
However the update does now allow windows application compatibility settings for DPI scaling to work for ArchiCAD 21 (previously they made no difference)
After patching ArchiCAD, AND toggling DPI scaling compatibility settings to 'on' then 'off' again, seems to clear the mouse pointer scaling issue
Process is: Right click the ArchiCAD 21 icon to access properties/compatibility settings, then tick to 'Override High DPI scaling behaviour' for all users, then apply. Restart PC (not 100% sure this step is required, but is what I did), then go back , right click icon again and revert compatibility settings for all users back to the default
Mouse pointer is then back to normal size.
Erwin Edel
Not helpful for the size, but if you find you keep losing the cursor, you can enable rulers, right click in them and choose cursor projection. You get cross hairs on your screen.
A bit of a hidden feature, so thought I'd mention it.
Would be nice if this gets fixed for whenever we do upgrade from HD screens to 4K, though.
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
Paul King
Thanks Erwin. After patching with preview 4004 update I discovered the problem can now be solved by also toggling DPI scaling compatibility settings on then off again as above - but ruler trick will help people waiting for the official release
Erwin Edel
Doesn't help with seeing the actual cursor icon any clearer I would assume though, but at least it is very obvious where it is
The broken work around toggle thing at least gives hope for a future fix!
www.leloup.nl
Windows 10 Pro
Paul King
OK, looks like the tiny mouse pointer bug is definitely not fixed - every time I reboot the PC, the problem is back.
You can clear it with the compatibility toggling procedure I outlined above, but users should not be forced to jump through these hoops every time the boot up their computer
Daniel Kovacs
Graphisoft Alumni
Graphisoft Alumni
Hello everyone,
We have just released the final version of the first update of ARCHICAD 21. The preview update (4004) had part of the solution for this problem, but the final version (4022) has the full solution, so make sure you have that installed!
In most cases installing the update should solve the issue, but sometimes (like in case of Paul King) this fix won't change a thing. In these cases you will have to manually set the cursor size from the Registry. You can find a full description of this issue and the solution in this Article:
http://helpcenter.graphisoft.com/?p=74887
Good Luck!
GRAPHISOFT
Learn and get certified!
