George wrote:
I think the crash report Karl is referring to can be found at ~/Library/Logs/CrashReporter .
Please provide it, it will help others if you can find a resolution.
Yes, thanks George/
Alternatively, Maged, to get to the same info, you can launch the Console application, in the View menu select "Show Log List" (if there is no left panel listing the logs). Then click through to FILES > ~/Library/Logs > CrashReporter and click on the recently dated ArchiCAD crash entry. You can select and copy part of the log entries from the right panel.
One of the forum moderators
AC 27 USA and earlier • macOS Ventura 13.6.6, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
