Setup & License forum
ArchiCAD25 bug on Monterey
VladGoo
my ArchiCAD25 give me a bug when I exit from a project workspace since I installed new version, MacOS Monterey. Have you any idea when will come a update for Archicad who solve this problem or if it's ok to use the program in this condition?
Best regards VT
2 ACCEPTED SOLUTIONS
timdelheyeian
Graphisoft US says that you need a version 40XX to run on Monterey. Graphisoft Germany says that such a version may be released next week.
In general, Graphisoft US recommends to wait 6 months past the release of a new macOS before switching, which is impossible to do when you buy a new Mac as they can typically not be back graded.
Certified Passive House Designer
ArchiCAD 25 (started with v4)
MacBook Pro (16-inch, 2021), Apple M1 Max, 64 GB, 32-core graphics
@VladGoo  See this article:
https://community.graphisoft.com/t5/Setup-License-articles/MacOS-12-Monterey/ta-p/309154
As @timdelheyeian stated, some of the international distributors have suggested on their web sites that an update may be arriving in the next few weeks.
It has always been ill-advised to update to a new MacOS until Graphisoft gives the green light.  As Tim stated, this is a frustrating issue for people buying new Macs, as there is no option to have them delivered with the prior OS.
One of the forum moderators   •   AC 26 USA and earlier   •   MacOS 11.6.8, iMac Pro
46 REPLIES 46
timdelheyeian
Mhm... OK, I understand.
What does it mean 40XX? 😄
That refers to the build number. Each major version of Archicad (like 25 for example) has a build number for releases and updates. The current version for the US for example is build 3011. Apparently, it will take a build number 40XX (so a newer build with a higher number to be (more) compatible with Monterey.
Here is the original GS article: https://community.graphisoft.com/t5/Setup-License-articles/MacOS-12-Monterey/ta-p/309154/redirect_fr...
Oh! OK! Thank you!
Well your recommendation is to downgrade to Big Sur?
That is what Graphisoft US tells its customers. However, when you buy a new Mac for instance, you may not be able to downgrade the macOS.
I have a new 16" M1 Max (on Monterey) coming next week. I will run it simultaneously with an older 16" (Intel on BigSur) and if I see anything of concern, I may post it here. I have run AC25 on an M1 MacMini (on BigSur) before and it worked okay. Since I updated that machine to Monterey, I have seen a couple of crashes.  Compatibility with Monterey appears to be the bottleneck here, as Apple's Rosetta seems to do a wonderful job translating Archicad 25 to AppleSilicon—as stated by Graphisoft support.
I too have a 16" M1 Max showing up this week, so I will be sure to do plenty of testing and report back.  Such a bummer that my brand new machine will be relegated to a testing device!
16" MacBook Pro M1 Max
Mac OS 12.2.1
ArchiCAD 25 Build 5010
According to that article, “This problem does not affect the migrated or new projects, these files can be saved and used without further issues.”
Has anyone tested to know what that actually means?
Eric Batte
Principal, MG Architects
I have mistakenly updated to OSX Monterey on M1 MacBook Pro. Both AC 24 and 25 are having serious issues. I can open existing drawings. I can work on them and save them. However you can't save as for any format file, you can't export PDF or DWG using publisher. When starting new project it can't be saved so only workaround is to copy existing file then rename it and work on it. Hopefully new versions of AC 24 and 25 resolve this otherwise it will have to be formatting the machine and reinstalling Big Sur.
Dear Sinisa,
Thank you for the report and I am very sorry to hear about the issue!
We tested this on macOS Monterey, but couldn't reproduce this. It looks like this is a machine-related problem. I suggest contacting your local support about this issue for further investigation.
Thank you for your understanding, and I hope that it will be solved quickly!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
After upgrading to Monterey OS we discovered an issue with the Open and Save dialog boxes. You might try the linked solution for save dialogs where as it also worked for a user that was having issues saving with Monterey and Archicad 25. Until Graphisoft releases an update try solving the issue with two Terminal commands as we describe in a Blog article we posted at this link >>
The problem is that the new M1 MacBook Pros come only with Monterey and there is no option to "downgrade" them to Big Sur. Last I checked Graphisoft was the official Apple developer. Graphisoft has access to all the pre-release versions of the macOS months before the release version ships.
For the money that Graphisoft charges for the annual updates they should be improving Archicad BEFORE the operating system is released. The update hot fix should be available as soon as the next macOS comes out. Telling everyone to "wait half a year" is not a very compelling proposition.
@pawelfiett  Supposedly, 25 Update 2, released today, will resolve some of the Monterey issues reported in the Monterey compatibility article.  (Strangely, nothing in the release notes even mentions Monterey.). If this is the case, then the "wait" has only been one week... as Monterey was only released last week...
I have a new MacBook Pro Max on order, due to arrive in late December/early January.  Obviously, that will be shipping with Monterey.  As a preparatory test, I am currently running Archicad 22 on a 2015 MacBook Pro and a 2018 MacBook Pro, both have Monterey 12.0.1 as the OS.  As stated by others in the thread, 22 runs fine with the exception of the "crash on close" and "overly-wide dialog box" issues.  I can live with that.
As a sole proprietor of residential projects, I really did not have a compelling reason to upgrade to 23, 24, or 25.  (This is actually the first time since release 8 that I have not succumbed to the annual subscription upgrade pressure, which is a bit refreshing.)
Hopefully, by release 26, Archicad with take advantage of the performance of the new apple silicon...
ArchiCAD since 8.0, currently on 22, waiting on 26, maybe...
Here is what a GS article says about this:
https://community.graphisoft.com/t5/Setup-License-articles/ARM-Mac-support/ta-p/304108
According to our plans, a full commercial release of Archicad
natively running on the ARM architecture is to be expected in 2022.
Get Archicad Tips at https://twitter.com/laszlonagy
AMD Ryzen 1700X CPU, 48 GB RAM, Nvidia GTX 1060 6GB, 500 GB NVMe SSD
2x28" (2560x1440), WIN10 PRO ENG, AC20-AC26
Loving Archicad since 1995
Eduardo Rolon
Update 02 has just been released.
eduardo rolón AIA NCARB
Another of the forum moderators.
Macbook Pro M1 Max 64GB ram
OS X 10.XX latest
AC25 US/INT -> AC08
Puerto Rico, BVI, Miami
Vectorworks 2022
Download the most recent update (Update 2) to ARCHICAD 25 which is described in this article:
https://community.graphisoft.com/t5/Let-s-get-started/Archicad-Keeps-Getting-Better-Archicad-25-Upda...
Many new features have been added.  Surprisingly, this is the update which is supposed to address some of the MacOS Monterey compatibility issues, yet the article does not mention that.   Please install when the update is available for your localization and report back if Monterey issues persist.
PS (I cannot edit my posts in Safari - a forum bug that is being worked on) ... Check for Updates within AC 25 reports that I am up-to-date when I am not.  I had to visit the Graphisoft update site to download AC 25 Build 4013.  Select your localization/etc from the drop-downs:
https://graphisoft.com/resources-and-support/downloads?localization=USA&type=AC&version=25
