Setup & License forum
ArchiCad 9 on Windows 10
ahamilton2076
Hello.
This is my first post to this forum. I've been been using ArchiCad 9 since 2004. When Windows XP was phased out I stubbornly kept using the program on a XP computer, but it's been a pain.
I just recently upgraded to windows 10 and successfully installed ArchiCad 9, it works fine but only in the demo mode. The WIBU key is not recognized by Windows 10. I wonder if anyone else has seen this and would love to see if I can update/get new drivers for my key.
I don't use ArchiCad enough to justifly purchasing a copy that is currently certified to run on Windows 10.
Any help will be much appreciated.
Thank you,
Dan
Dan
2 REPLIES 2
Try downloading the Windows 10 compatible WIBUKey driver here:
http://www.graphisoft.com/downloads/protection_key.html
If you're still stuck, run the AC "File Converter" version of 9 - with your existing US 9 (or whatever) library and template. As stated in the link,
you'll need QuickTime installed:
http://www.graphisoft.com/downloads/fileconverter.html
Download the AC 9 USA package from that link and see if it'll run for you, possibly without your WIBU key.
If none of the above helps - or AC 9 doesn't run properly once it is running on Windows 10, you might (??) have to continue to run XP in a virtual machine on your Win 10 machine...
One of the forum moderators   •   AC 26 USA and earlier   •   macOS Ventura 13.2.1, iMac Pro 10-Core, Radeon Pro Vega 64
ahamilton2076
Hi Karl,
Thanks for the tips. I'll download the drivers and give it a go. I've thought about running a virtual xp machine instead of booting from a 2nd hard drive.
Have you had any experience with running a xp virtual machine and can you recommend one you've had experience with?
Thanks for your help. It will take me a few days to try this but I'll get back to you with the results.
Dan
