Installation & update
Archicad 18 - installation and run error
I just downloaded archicad 18 - student version, and I got my serial number just fine, but when the installation continues, just at the end, I get an error message "GXMedia.dll not found. File must be available to run the application!" When I try to run the software, I get the same error and then it just exits.
I tried un-installing and re-installing a couple of times, and still the same error.
A little help would be appreciated!
Thanks a lot!
16 REPLIES 16
Hi, I had the same problem with ArchiCAD 19 INT and ArchiCAD 18 SPA in Windows 10 Pro N.
How to solve the GXMedia.dll not found error in Windows 10 Pro N:
1. Download and install Media Feature Pack for N and KN versions of Windows 10.
2. Profit. That's it. No more steps.
Graphisoft should fix this error. Many Windows in Europe doesn't include the media pack. Or at least, be more verbose about how to fix it.
I will bring this issue to the attention of the guys at Graphisoft.
Katalin Borszeki
Thanks for notifying us. We are investigating this issue.
Until then, we recommend to download the Media Feature Pack for the N and KN versions of Windows 10 prior installing ARCHICAD, as Guibuu mentioned in a previous post.
Katalin Borszeki
Implementation Specialist
GRAPHISOFT
Katalin Borszeki
Please see our Helpcenter article on this issue:
http://helpcenter.graphisoft.com/?p=48274
Katalin Borszeki
GRAPHISOFT
Hi, few days ago Windows 10 got its first big update (Windows 10 Pro N x64 version 1511, OS compilation 10586.3), and since them I can't start neither ArchiCAD 18 SPA 4020 nor ArchiCAD 19 SPA 4006 in Windows 10. The old "GXMedia.dll not found. File must be available to run the application!" returned, so I tried to apply the "Media Feature Pack for N and KN versions of Windows 10" update (Windows10-KB3010081-x64.msu). But sadly, this time this update doesn't solved the problem
I've tried to:
  • Launch ArchiCAD (GXMedia.dll error appears).
  • Install KB3010081, restart, launch ArchiCAD (GXMedia.dll error appears).
  • Install KB3010081 ("already installed" message appears), repair ArchiCAD (GXMedia.dll error appears at the end of the process, when it tries to launch ArchiCAD), launch ArchiCAD (GXMedia.dll error appears).
Windows 10 updates can't be stopped (and it's not recommended to block them anyway), so help, please!
Greg Kmethy
Try to run the ARCHICAD installer in "repair" mode, then re-install the latest ARCHICAD update. Maybe one component of ARCHICAD was blocked by your virus checker or by some Windows security mechanism. Sometimes those misfire.
Gergely Kmethy
Tried it, with no result.
Also, this is what I have done today:
  • Windows 10 fully updated
  • Downloaded and installed Windows10-KB3010081-x64.msu (already installed it yesterday) and Windows10-KB3010081-x86.msu updates
  • Restarted PC
  • Uninstalled ArchiCAD 19 (that's funny, even in the uninstaller the GXMedia.dll error appears, but the uninstaller worked)
  • Restarted PC
  • Disabled my antivirus (only have Windows Defender, I have disabled real-time protection and cloud-based protection)
  • Installed AC19-3003-SPA.exe (GXMedia.dll error appears at the end of the process)
  • Restarted PC
  • Installed ArchiCAD-19-Update-4006.exe
  • Restarted PC
  • Launched ArchiCAD 19. GXMedia.dll error appears, ArchiCAD cannot be started
________
Edit 2015-11-19:
I have bypassed this error by returning to an old Windows compilation (Settings > Update & security > Recovery). My Windows version is now Windows 10 Pro N (version 10.0, compilation 10240).
Now ArchiCAD 18 & 19 works as expected.
I'm sad to say this, but currently ArchiCAD is NOT compatible with the last version of Windows 10 Pro N.
