Installation & update
Archicad 21 slow
KeesW
I am using AC21 on a small project and find some of its operations much slower that I am used to in previous versions. When I select la working on a model, the scrolled list takes measurable time to appear. When I scroll this list up or down, it takes measurable seconds to actually scroll and it stops and starts. The response to menu selections is also sometimes tardy. I've never had this with previous AC versions.
Am I alone in finding this?
Cornelis (Kees) Wegman
cornelis wegman architects
21 REPLIES 21
KeesW wrote:
Barry
How do I delete or disable the GeForce Experience program? Have I even got it?
Go into Control Panel > Programs & Features.
Look through the list for a program called 'Nvidia GeForce Experience'.
If it is there, right click on in and remove/uninstall.
If its not there then you don't have it.
You may have other Nvidia programs and drivers in that list - they should be fine.
hey all,
I've been having similar issues lately, general 2d is really slow, deselecting is a second, 2 secs sometimes more. It has been getting really noticeable and annoying.
Have just updated to a new driver released 29th Jan.
Seems to have been a big improvement thus far.
check your graphics card drivers https://www.geforce.com/drivers
ps: disabling geoforce experience has had no effect (for me) before or after updating too, but that's not to say it won't work for others.
updated
since installing the latest library update for 21 (yesterday)
ac has reverted back to being slow and tedious....
alemanda
...still struggling with AC21 slow down ...
I don't understand what causes so much slowness ...
The same file in the laptop works much better ...
AC 19 and AC21 latest hotfix
Win 10 Pro 64bit
Double XEON 14 CORES (tot 28 physical cores)
32GB RAM - SSD 256GB - Nvidia Quadro K620
Display DELL 25'' 2560x1440
www.almadw.it
I also have performance issues with Archicad 21. Its getting amazingly frustrating. Its even slow when i start a new project file.
The UI redraw is sluggish. If i change between element the properties tab takes 2-3 seconds to load. I get constant loading circle from windows. the viewport is also very slow.
And this is not only on windows. I experience the same thing on mac os.
I have absolutely no idea why this is happening. i have the latest updates for everything
a few months ago everything was running fine.
My hardware:
PC - win 10 pro, ryzen 1700, 32gb ram, gtx 1070, 500gb ssd
MAC - high sierra, fully decked out 15" MBP mid 2014 2.5 ghz i7, 16gb ram, gt 750m
You have 2 different machines - PC and MAC.
Is the same thing happening on both?
yes.
Options > Work Environment > Advanced Redraw Options>Model Display in 2D Navi>Structural Contours Onlyours Only for quickly navigation !
ares997
In Work Environment > Company Standards and Schemes > Data Safety and Integrity > Save and Recovery options
Adjust the frequency of backups from Ultra Safe to something more reasonable like 5 or 20 minuet intervals.
Also in User Preferences Schemes > Model Rebuild Options there are some adjustments that can be made there that might enable better performance.
Archicad 25 (5005), Windows 11, AMD RYZEN 7 3900 (64 GB RAM)
Also have a look at this post.
https://archicad-talk.graphisoft.com/viewtopic.php?f=13&t=59564
There are a couple of other similar ones I think if you do a bit of searching.
Try setting some exceptions in you virus scanning software.
This seems to have helped many people in speeding Archicad up.
Learn and get certified!
