Installation & update
SOLVED!
Archicad 22 Renovation Filter Crash (Win10)
Takis
Bug I.D: AC22-2018-07-08-08-49-47-2134
The file was imported from Archicad 21 version .
After editing the project (structural elements), I did the following in the Existing Renovation Filter settings:
1. Override Existing Elements - click OK
2 . Show Existing Elements, Override Demolition Elements - click OK
3 . Crash.
4. Reopen file "Show Existing Elements, Override Demolition Elements" - click OK crashed again.
5. Reopen file "Change Renovation Filter to Demolition Plan", open Renovation Filter settings and make the default changes to Existing Filter.
6. File now is working OK but no changes are done in Renovation Filter settings for any Renovation plan.
Archicad 22 Int. Built 3006
Macpro 2013 (Bootcamp)
Takis
1 ACCEPTED SOLUTION
Solution
Daniel Kovacs
Graphisoft Alumni
Graphisoft Alumni
Hello guys,
We looked into that crash, and it seems to be caused by an unfortunate state of multiple things. In the first update we are planning to patch a few of those, which should make this go away, but in the meantime here's what can be done about it:
- In Takis' project there are several Line elements in the floor plan with their 'Line Category' set to 'Skin Separator Line'. If you switch these back to 'Drafting Line', that should help. You can find these fast with Find & Select.
- The crash is triggered when you change the Renovation status in the Renovation Filter Options window, and then click OK. You can go around this, by setting up the Filters prior, and then only changing the Filters through the Quick Options bar/palette.
Regards,
Daniel Alexander Kovacs
GRAPHISOFT
4 REPLIES 4
This is a user forum, and not the place to report bug ID's and crash details, although your report (other than the ID) may be helpful to fellow users. Sounds like a critical bug and super frustrating for you! 😞
If you did not add the reproduction steps and your email address to the crash log that you submitted to Graphisoft, please contact your local technical support to have it attached. Posting here will not do so.
Finally - for we users, and for GS - what do you mean by "Bootcamp" for your Mac Pro? Do you mean that you are running AC 22 under Windows under Bootcamp? If so, what version of Windows? If you are running under MacOS - then what version of MacOS?
Karl
One of the forum moderators
AC 27 USA and earlier   •   macOS Ventura 13.6.6, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Takis
Hi Karl, I am running AC22 under windows 10 under Bootcamp.
Takis
Thanks, Takis. I've modified the subject line for this thread to clarify that I could be a bug limited to the Windows implementation. Will remove that if a MacOS user reports the same issue ... or if you happen to be able to try to reproduce under MacOS. 🙂
Solution
Daniel Kovacs
Graphisoft Alumni
Graphisoft Alumni
Hello guys,
Regards,
GRAPHISOFT
Learn and get certified!
