2020-08-23 07:20 PM
2020-08-23 07:59 PM
2020-08-24 01:32 AM
2020-08-24 06:12 AM
2020-08-24 06:52 PM
2020-08-25 12:00 AM
2020-08-31 02:21 AM
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
2020-08-31 02:59 AM
2020-08-31 03:32 AM
DGSketcher wrote:Hello,
Hi Minh, I am on an 3.6GHz i9 8 core with 16Gb Ram and 512Gb SSD working on a 110Mb .PLN file and the save process not only for the PLN file but also each MOD file is painfully slow and a lot longer than I would have expected. Activity Monitor frequently shows Archicad as Not responding. I am using about 12Gb of my 16Gb ram. As I mentioned above on first install AC24 was flying on Save now it seems to crawl following the last Mac update.
I have just opened the file and the attached shows the memory report for Archicad, what troubles me about this is it is reporting 3 hangs already!? Having done no work and resaved the file it has now increased to 6 hangs and the virtual memory has jumped!!! Surely this isn't normal?
Minh Nguyen
GRAPHISOFT
2020-08-31 04:18 AM
2020-08-31 04:48 AM
Minh Nguyen
GRAPHISOFT
2020-08-31 01:22 PM
2020-09-01 12:31 AM
Minh Nguyen
GRAPHISOFT
2020-09-01 01:34 AM
mnguyen wrote:Hi Minh,
6 minutes for 9 modules, each with ~2MB size is not too bad, it's actually quite normal, or even pretty good.
2020-09-01 01:45 AM
Minh Nguyen
GRAPHISOFT
2020-09-07 08:11 AM
2020-09-08 06:41 AM
Minh Nguyen
GRAPHISOFT
2020-09-10 03:39 AM
Archicad 4.55 - 25 | HP Z840 | 2× E5-2643 v4 | 64 GB RAM | Nvidia Quadro M5000 @ Windows 10 Pro x64
2020-09-10 05:14 AM
2020-09-10 05:46 AM
