Hello,
Thank you very much for sharing the issues and I am very sorry about the experience!
For the CineRender crashes, there could be a few reasons that might cause this. In most cases, the Cineware.exe was not running when rendering was initiated. We have the following investigation steps to identify the issue:
1. Can the user render anything?
- Yes, but after a few renderings it fails: maybe Cineware.exe has quitted or crashed. Please see the 3rd step
- No: See next step.
2. Was the user able to render something in the past?
- Yes: probably a Windows update somehow ruined the dependencies. Please try to reinstall the following Redistributables:
https://helpcenter.graphisoft.com/knowledgebase/73567/
3. After starting Archicad, check whether the Cineware process is running in Task Manager. Did Cineware process start with Archicad?
- Yes: If AC starts up with Cineware, but the rendering process dies silently or perhaps upon a "Cineware by MAXON add-on has unexpectedly closed" warning, it's possible that Cineware faced problems in communicating with your graphics card's driver, or an antivirus program killed it.
- No: If Cineware is not running, it might have a problem starting up. We have a special script for this issue. Please let us know if this is the case.
Regarding the slowness at startup even in the latest update, there could be multiple reasons: outdated graphics driver (especially if you have integrated Intel GPU), trouble with finding a license, or antivirus blocking. We also have a special tool for diagnosing Archicad freeze issues. Please let me know if you are interested in further investigation!
Looking forward to hearing from you soon!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
