Installation & update
Archicad 24 technical requirements
Hello there!Can you tell me if Archicad 24 runs on Windows 10 Home 2004?
5 REPLIES 5
Jp1138
Yes, it does. Why wouldn´t it?
ARCHICAD 27 SPA
Windows 10
when installing the program, it reports that windows is not supported
Erwin Edel
You are probably using a 32-bit version of windows 10 then.
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
Lingwisyer
Guru
Wow, I did not even realise there was a 32 bit version of Win10. Anyway, if you are running on a 32 bit system due to hardware limitations, your system falls well short of ArchiCADs minimum requirements...
Minh Nguyen
Graphisoft Alumni
Graphisoft Alumni
Hi Mikey,
Thank you for the question and I am sorry to hear about the issue!
Unless you have 32-bit Windows 10 installed, we sometimes have reports about "out-of-date" OS when installing Archicad. The solution usually is to install Microsoft Redistributable. Please follow the article here, and install all necessary elements: https://helpcenter.graphisoft.com/knowledgebase/73567/
Please let me know if this helps!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
