2021-12-03 08:45 AM
Help please,
I can´t resize Open / Save dialog box on macOS Monterey.
Archicad 25 4013
Thank you.
Solved! Go to Solution.
2021-12-03 08:55 AM
It's a known bug. Check the following tutorial on how to fix it.
https://www.learnvirtual.com/how-to-resize-long-open-save-dialog-boxes-in-Archicad-on-mac-monterey/
2021-12-03 09:30 AM
Thank you! 👌
2022-02-17 11:43 AM
That's great! Anyone know what the command is to fix it for AC24?
2022-02-17 12:16 PM
Dunno, but you can try to replace 25 with 24:
defaults delete com.graphisoft.archicad24 NSNavPanelExpandedSizeForSaveMode
defaults delete com.graphisoft.archicad24 NSNavPanelExpandedSizeForOpenMode
2022-02-17 12:24 PM
Yes, that doesn't work. If I find the soltution I will post it.
2022-02-17 12:25 PM
you can use my Shortcut for Archicad 23 - and edit it, just by changing 23 to 24 or 25.
It works lightning fast and it became no more annoying
2022-02-17 12:28 PM
The preview build 7000 states that bug as fixed. Don't update if you are working with others in teamwork tho, projects opened with b7000 won't be usable on previous builds.
2022-02-17 12:33 PM
Awesome - much appreciated!
2022-02-17 12:34 PM
Thanks Kruchy!
