2021-10-17 04:37 PM
Hi all, I've just installed Archicad 25 and i'm having consistant crashes on my machine and all members of the team (5 people)
Seems to crash on publishing to PDF everytime it gets to the section veiw sheets. I had the same issues with 24 when it was first installed, that got fixed in the first update. i'm running build 3011 with 25.
Bug ID: AC25-2021-10-17-23-33-18-1804
2021-10-17 07:21 PM
Be sure to follow that bug ID up with your local Archicad support people.
Don't rely on someone from Graphisoft picking it up here, it might happen but it might not.
I would also try publishing just one page at a time, and if a particular page crashes it may help you determine what might be on it that is causing the problem.
If that page has multiple sections and details, create a new page with just one of those drawings at a time on it.
A process of elimination to try and figure out what the cause is.
2021-10-17 07:57 PM
the probelm is the section page like i stated. Already went through that process to detirmine the issue.
Seems to be when the views regenerate. The workaround at the moment is, making sure i've opened the page and let the section views update before publishing. If that isn't done it will crash every time. already sent it on to Archicad, waiting for reply. Though i would post here incase its an issue for everyone else and there may have been an easy fix.
2021-10-17 11:28 PM
Uncommon, but just noting FYI: Do you have any special characters in your section or file name? I’ve occasionally had AC hang up on PDF creation due to some sort off syntax issue.
2021-10-17 11:30 PM
interesting, there is a degree symbol on the sections for the roof.... could be it
2021-10-17 11:54 PM
… or a bad object in the section, like a stair that is not calculating properly in section (though that normally returns an error). Maybe try a different, simpler, section and see if that one is successful.
2021-10-26 05:22 AM - edited 2021-10-26 05:23 AM
Dear tomyg,
Thank you very much for the bugID and I am very sorry for the issue!
Based on the crash report, we found that this is a rare bug that has just been found recently (DEF-5582). In one case, we found that it is caused by autotext labels on the section which have autotexts displaying zone-related properties (for example "Related Zone Name").
But the crash occurs only if the source section is opened while updating the drawing. So as a simple workaround we can close the section window before updating the drawing.
I'm wondering if it gives you a hint on the problem here?
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
2021-10-26 04:36 PM
Tested this morning, crashed when source section is open. Did not crash when source section was closed.
Thank you for looking into that one. I remember having a similar issue when 24 came out.
I have a whole heap of other bug numbers. I'm not sure if that'll help, sounds like we've found my main issue there.
AC25-2021-10-22-01-46-10-9460
AC25-2021-10-22-01-54-53-5171
AC25-2021-10-22-04-35-57-8871
AC25-2021-10-22-04-38-15-7320
AC25-2021-10-25-03-57-57-1712
