Installation & update
Archicad Licence was not found
If anybody could help me, it would be greatly appricated.
I have been trying for two evenings without luck to get Archicad 17 to work on my home computer as well as my work mac to get some work done at home.
I have come to the conclusion that codemeter control center is impossible to understand.
I use archicad 17 solo edition at work using a single key codemeter dongle. In theory I should be able to just plug this into my home computer to work, but everything I have tried will give me the same error in archicad when it loads.
"ArchiCAD licence was not found (Codemeter error:230)"
I work on a new Imac at work using the lastest version of mavericks.
At home where I am trying to get it to work I use a HP Envy on Windows 8.1.
I have updated archicad with the latest hotfix 7.
I have updated the firmware on the codemeter. I have updated the codemeter runtime to the latest.
Within the codemeter events everytime I try to load Archicad 17 I get:
2014-06-24 19:57:27: Logging activated.
2014-06-24 19:57:27: CodeMeter for Windows (B5.10.1241.503.32.150)
2014-06-24 19:57:27: Running on Microsoft Windows 6.3
2014-06-24 19:57:27: Execution path: C:\Program Files (x86)\CodeMeter\Runtime\bin
2014-06-24 19:57:27: Application Uptime: 00:00:11 up
2014-06-24 19:57:27: Found IPv4 address: 127.0.0.1 | 192.168.0.16
2014-06-24 19:57:27: Found IPv6 address: ::1 | fe80::70aa:8659:8c8d:f1a5%3 | fe80::a5eb:c598:c211:4a08%17 | fe80::b1f1:eb6d:e737:2c92%4 | fe80::bdcc:fdd1:c94f:64da%5
2014-06-24 19:57:27: Used Communication Mode: IPv6 IPv4 SharedMemory
2014-06-24 19:57:27: Used IP address: default address
2014-06-24 19:57:27: Used IP port: 22350
2014-06-24 19:57:27: Used CmWAN port: 22351
2014-06-24 19:57:27: Multicast server search: not available
2014-06-24 19:57:27: Run as network server: no
2014-06-24 19:57:27: Run as CmWAN server: no
2014-06-24 19:57:27: Run as system service: yes
2014-06-24 19:57:27: Box Access: use direct access mode
2014-06-24 19:57:28: Detecting CmContainer with Serial Number 2-2474730
2014-06-24 19:57:29: A new CmContainer is available (currently found 1)!
2014-06-24 19:57:29: The list of available CmContainers has been updated!
2014-06-24 19:57:29: Found new entries: 2
2014-06-24 19:57:42: Entry (101074:61:134741023) not found - Event WB0030 (FEATURE MAP INCOMPATIBLE), Request IP-Address local(IPV6)
2014-06-24 19:57:42: API Error 30 (FEATURE MAP INCOMPATIBLE) occurred!
2014-06-24 19:57:42: Entry (5000003:61:134741023) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV6)
2014-06-24 19:57:42: API Error 200 (ENTRY NOT FOUND) occurred!
2014-06-24 19:57:42: Executing Broadcast for CodeMeter License Servers
2014-06-24 19:57:43: Entry (101074:61:134741023) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV6)
2014-06-24 19:57:43: API Error 200 (ENTRY NOT FOUND) occurred!
2014-06-24 19:57:43: Executing Broadcast for CodeMeter License Servers
2014-06-24 19:57:44: Entry (5000003:61:134741023) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV6)
2014-06-24 19:57:44: API Error 200 (ENTRY NOT FOUND) occurred!
2014-06-24 19:57:44: Entry (101074:61:134741023) not found - Event WB0030 (FEATURE MAP INCOMPATIBLE), Request IP-Address local(IPV6)
2014-06-24 19:57:44: API Error 30 (FEATURE MAP INCOMPATIBLE) occurred!
2014-06-24 19:57:45: Entry (5000003:61:134741023) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV6)
2014-06-24 19:57:45: API Error 200 (ENTRY NOT FOUND) occurred!
2014-06-24 19:57:45: Executing Broadcast for CodeMeter License Servers
2014-06-24 19:57:46: Entry (101074:61:134741023) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV6)
2014-06-24 19:57:46: API Error 200 (ENTRY NOT FOUND) occurred!
2014-06-24 19:57:46: Executing Broadcast for CodeMeter License Servers
2014-06-24 19:57:47: Entry (5000003:61:134741023) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV6)
2014-06-24 19:57:47: API Error 200 (ENTRY NOT FOUND) occurred!
2014-06-24 19:57:47: Entry (101074:61:134741023) not found - Event WB0030 (FEATURE MAP INCOMPATIBLE), Request IP-Address local(IPV6)
2014-06-24 19:57:47: API Error 30 (FEATURE MAP INCOMPATIBLE) occurred!
2014-06-24 19:57:47: Executing Broadcast for CodeMeter License Servers
2014-06-24 19:57:48: Entry (101074:61:134741023) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV6)
2014-06-24 19:57:48: API Error 200 (ENTRY NOT FOUND) occurred!
2014-06-24 19:57:48: Executing Broadcast for CodeMeter License Servers
2014-06-24 19:57:49: Entry (5000003:61:134741023) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV6)
2014-06-24 19:57:49: API Error 200 (ENTRY NOT FOUND) occurred!
2014-06-24 19:58:30: Entry (101074:61:134741023) not found - Event WB0030 (FEATURE MAP INCOMPATIBLE), Request IP-Address local(IPV6)
2014-06-24 19:58:30: API Error 30 (FEATURE MAP INCOMPATIBLE) occurred!
2014-06-24 19:58:30: Entry (5000003:61:134741023) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV6)
2014-06-24 19:58:30: API Error 200 (ENTRY NOT FOUND) occurred!
2014-06-24 19:58:30: Executing Broadcast for CodeMeter License Servers
2014-06-24 19:58:31: Entry (101074:61:134741023) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV6)
2014-06-24 19:58:31: API Error 200 (ENTRY NOT FOUND) occurred!
2014-06-24 19:58:31: Executing Broadcast for CodeMeter License Servers
2014-06-24 19:58:32: Entry (5000003:61:134741023) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV6)
2014-06-24 19:58:32: API Error 200 (ENTRY NOT FOUND) occurred!
2014-06-24 19:58:32: Entry (101074:61:134741023) not found - Event WB0030 (FEATURE MAP INCOMPATIBLE), Request IP-Address local(IPV6)
2014-06-24 19:58:32: API Error 30 (FEATURE MAP INCOMPATIBLE) occurred!
2014-06-24 19:58:32: Executing Broadcast for CodeMeter License Servers
2014-06-24 19:58:33: Entry (101074:61:134741023) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV6)
2014-06-24 19:58:33: API Error 200 (ENTRY NOT FOUND) occurred!
2014-06-24 19:58:33: Executing Broadcast for CodeMeter License Servers
2014-06-24 19:58:34: Entry (5000003:61:134741023) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV6)
2014-06-24 19:58:34: API Error 200 (ENTRY NOT FOUND) occurred!
2014-06-24 19:58:34: Entry (101074:61:134741023) not found - Event WB0030 (FEATURE MAP INCOMPATIBLE), Request IP-Address local(IPV6)
2014-06-24 19:58:34: API Error 30 (FEATURE MAP INCOMPATIBLE) occurred!
2014-06-24 19:58:34: Executing Broadcast for CodeMeter License Servers
2014-06-24 19:58:35: Entry (101074:61:134741023) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV6)
2014-06-24 19:58:35: API Error 200 (ENTRY NOT FOUND) occurred!
2014-06-24 19:58:35: Executing Broadcast for CodeMeter License Servers
2014-06-24 19:58:36: Entry (5000003:61:134741023) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV6)
2014-06-24 19:58:36: API Error 200 (ENTRY NOT FOUND) occurred!
2014-06-24 20:10:12: Entry (101074:61:134741023) not found - Event WB0030 (FEATURE MAP INCOMPATIBLE), Request IP-Address local(IPV6)
2014-06-24 20:10:12: API Error 30 (FEATURE MAP INCOMPATIBLE) occurred!
2014-06-24 20:10:12: Entry (5000003:61:134741023) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV6)
2014-06-24 20:10:12: API Error 200 (ENTRY NOT FOUND) occurred!
2014-06-24 20:10:12: Executing Broadcast for CodeMeter License Servers
2014-06-24 20:10:13: Entry (101074:61:134741023) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV6)
2014-06-24 20:10:13: API Error 200 (ENTRY NOT FOUND) occurred!
2014-06-24 20:10:13: Executing Broadcast for CodeMeter License Servers
2014-06-24 20:10:14: Entry (5000003:61:134741023) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV6)
2014-06-24 20:10:14: API Error 200 (ENTRY NOT FOUND) occurred!
2014-06-24 20:10:14: Entry (101074:61:134741023) not found - Event WB0030 (FEATURE MAP INCOMPATIBLE), Request IP-Address local(IPV6)
2014-06-24 20:10:14: API Error 30 (FEATURE MAP INCOMPATIBLE) occurred!
2014-06-24 20:10:14: Executing Broadcast for CodeMeter License Servers
2014-06-24 20:10:15: Entry (101074:61:134741023) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV6)
2014-06-24 20:10:15: API Error 200 (ENTRY NOT FOUND) occurred!
2014-06-24 20:10:15: Executing Broadcast for CodeMeter License Servers
2014-06-24 20:10:16: Entry (5000003:61:134741023) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV6)
2014-06-24 20:10:16: API Error 200 (ENTRY NOT FOUND) occurred!
2014-06-24 20:10:16: Entry (101074:61:134741023) not found - Event WB0030 (FEATURE MAP INCOMPATIBLE), Request IP-Address local(IPV6)
2014-06-24 20:10:16: API Error 30 (FEATURE MAP INCOMPATIBLE) occurred!
2014-06-24 20:10:16: Executing Broadcast for CodeMeter License Servers
2014-06-24 20:10:17: Entry (101074:61:134741023) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV6)
2014-06-24 20:10:17: API Error 200 (ENTRY NOT FOUND) occurred!
2014-06-24 20:10:17: Executing Broadcast for CodeMeter License Servers
2014-06-24 20:10:18: Entry (5000003:61:134741023) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV6)
2014-06-24 20:10:18: API Error 200 (ENTRY NOT FOUND) occurred!
2014-06-24 20:14:27: Entry (101074:61:134741023) not found - Event WB0030 (FEATURE MAP INCOMPATIBLE), Request IP-Address local(IPV6)
2014-06-24 20:14:27: API Error 30 (FEATURE MAP INCOMPATIBLE) occurred!
2014-06-24 20:14:27: Entry (5000003:61:134741023) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV6)
2014-06-24 20:14:27: API Error 200 (ENTRY NOT FOUND) occurred!
2014-06-24 20:14:27: Executing Broadcast for CodeMeter License Servers
2014-06-24 20:14:28: Entry (101074:61:134741023) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV6)
2014-06-24 20:14:28: API Error 200 (ENTRY NOT FOUND) occurred!
2014-06-24 20:14:28: Executing Broadcast for CodeMeter License Servers
2014-06-24 20:14:29: Entry (5000003:61:134741023) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV6)
2014-06-24 20:14:29: API Error 200 (ENTRY NOT FOUND) occurred!
2014-06-24 20:14:29: Entry (101074:61:134741023) not found - Event WB0030 (FEATURE MAP INCOMPATIBLE), Request IP-Address local(IPV6)
2014-06-24 20:14:29: API Error 30 (FEATURE MAP INCOMPATIBLE) occurred!
2014-06-24 20:14:29: Executing Broadcast for CodeMeter License Servers
2014-06-24 20:14:30: Entry (101074:61:134741023) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV6)
2014-06-24 20:14:30: API Error 200 (ENTRY NOT FOUND) occurred!
2014-06-24 20:14:30: Executing Broadcast for CodeMeter License Servers
2014-06-24 20:14:31: Entry (5000003:61:134741023) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV6)
2014-06-24 20:14:31: API Error 200 (ENTRY NOT FOUND) occurred!
2014-06-24 20:14:32: Entry (101074:61:134741023) not found - Event WB0030 (FEATURE MAP INCOMPATIBLE), Request IP-Address local(IPV6)
2014-06-24 20:14:32: API Error 30 (FEATURE MAP INCOMPATIBLE) occurred!
2014-06-24 20:14:32: Entry (5000003:61:134741023) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV6)
2014-06-24 20:14:32: API Error 200 (ENTRY NOT FOUND) occurred!
2014-06-24 20:14:32: Executing Broadcast for CodeMeter License Servers
2014-06-24 20:14:33: Entry (101074:61:134741023) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV6)
2014-06-24 20:14:33: API Error 200 (ENTRY NOT FOUND) occurred!
2014-06-24 20:14:33: Executing Broadcast for CodeMeter License Servers
2014-06-24 20:14:34: Entry (5000003:61:134741023) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV6)
2014-06-24 20:14:34: API Error 200 (ENTRY NOT FOUND) occurred!
I have also disabled firewall and installed archicad 17 multiple times. I have been through lots of forums and have been driven to dispare. I would like to do some work now.
Many thanks in advance for any replys.
Francis
Since your license is for the special UK "Solo" edition... is it indeed the Solo edition that is installed on your home computer as well?
Most of the error messages - which don't seem to have anything to do with AC per se - are related to the fact that your Windows network has both IPv4 and iPv6 network addresses enabled. Seems that Microsoft enables both by default - even though almost nobody is on an IPv6 network yet... Is there a reason that you have IPv6 enabled for your Windows network adapter?
http://support.microsoft.com/kb/929852
You may need to contact UK tech support.
One of the forum moderators
I know this is an old topic but it would be good if someone could share what is the solution for this problem.
I have got the same error message even after disabling the ipv6 unfortunately.
Does someone know how to solve this?
Regards,
Eszter
