Licensing
About all sorts of licenses, their management, Graphisoft ID, Graphisoft Store, License Manager Tool, etc.
Archicad and Licence Manager can't connect to the network
Hi. I just purchased the software and after installing the applications I can't run any of them. Also, I had issues with accessing graphisoft id website. Seems like my computer is blocking the graphisoft website and apps. I turned off firewall, but still no luck in connecting.
I work on macOS Catalina 10.15.4
What could be a reason I can't access the software. Please help
14 REPLIES 14
Minh Nguyen
Graphisoft Alumni
Graphisoft Alumni
Thank you very much for the question!
May I ask, when you open Graphisoftid.graphisoft.com, does the browser load anything, or does an empty page appear (or even worse, no connection error appears)?
Happy New Year!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
Ні, the same problem only on windows 11, can you make a post with a solution to the problem? We will be very grateful!
hello, I saw that you had the same problem with logging into grafisoft id, can you tell me if you found a solution?
Hi, at windows 10 - problem was solved by advice from @Minh Nguyen
1 go to: C:\Windows\System32\drivers\etc
2 open Hosts (with wordpad or notepad)
3 delete all lines from # Graphisoft Anti-license checks by Up7 till the end. Once you're done, press Control + O to save the changes.
4 close editor ( Control + X )
d.m.
Hallo, I have the same problem. I have attached 2 screenshots of my terminal and licence manager tool.  Please help:)
Thank you in advanced!
Bildschirm­foto 2023-02-09 um 14.42.40.pngBildschirm­foto 2023-02-09 um 14.42.32.png
