Archicad crashed, previously saved file, was not in the recovery file
I recently had my Archicad file crash, and I re-entered the file, with a banner showing up with recover the file, and I had clicked that, however, the previous work before it had crashed (work I had done days prior and saved multiple times), was not there in the recovery file, that I had clicked. I am struggling to find a way to get it back, even if there is one.
I would have expected the recovery file would be the same as the one I had before it crashing, and have saved multiple times, but it isn't, would be nice if anyone could offer any insight or help!
Marc H
Normally you will find a .bpn file in the same directory as your .pln, which is the prior saved version of your .pln. You can open that file and save as a new .pln.
“The best thing about the future is that it comes one day at a time.” - Abraham Lincoln
AC27 USA on 16” 2019 MBP (2.4GHz i9 8-Core, 32GB DDR4, AMD Radeon Pro 5500M 8G GDDR5, 500GB SSD, T3s, Trackpad use) running Sonoma OS + extended w/ (2) 32" ASUS ProArt PAU32C (4K) Monitors
The recovery file should be the latest changes you made to the file - so long as you have not down graded the auto save options in the Work Environment.
It certainly shouldn't be days old.
If you have saved recently then there should be a BPN (backup) file in the same job directory as Marc mentioned.
Again, so long as you have not turned of the backup option in the Work Environment.
