The recovery file should be the latest changes you made to the file - so long as you have not down graded the auto save options in the Work Environment.
It certainly shouldn't be days old.
If you have saved recently then there should be a BPN (backup) file in the same job directory as Marc mentioned.
Again, so long as you have not turned of the backup option in the Work Environment.
Versions 6.5 to 25
Dell Precision 3510 - i7 6820HQ @ 2.70GHz, 16GB RAM, AMD FirePro W5130M, Windows 10
