Installation & update
Archicad crashes on start up
3tp
I'm trying to run archicad (21,22,23) on my father's pc, but crashes on start up and graphisoft bug reporter, also crashes.
PC runs windows 10 pro ver 2004 64bit,
cpu:Intel xeon E5620 2,4GHz
RAM: 6,00 GB
GPU: NVIDIA Quadro FX 1800
I tried unistall and reinstall, i talked with the reseller here in Greece and they have no idea how to fix it.
A week before, archicad was running fine on that particular PC.
Any ideas?
14 REPLIES 14
3tp
mnguyen wrote:
Hi Tim,
Thank you for the question!
Yes, it is true as Miha said, that this feature needs to be disabled. Could you give it a go and see if it helps?
Best regards,
Minh
I did a windows system restore, I reinstalled archicad and problem is resolved.
Thanks for all the replays,
mnguyen wrote:
Hi Tim,
Best regards,
Minh
I tried both with it enabled and disabled, but it unfortunately doesn't seem to work either way.
Ah, yes i guess this would be the last resort, but if nothing else works i'll try that.
Minh Nguyen
Graphisoft Alumni
Graphisoft Alumni
Hi Tim,
I'm wondering if you keep any bugID of the crash? Normally, if the Bug Reporter shows up after a crash, a bugID should be created after you send the information to us (https://helpcenter.graphisoft.com/knowledgebase/64553/)
If you are on Archicad 24, here is the guide: https://helpcenter.graphisoft.com/knowledgebase/130130/
These IDs would be very crucial for identifying what triggers the crash!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
mnguyen wrote:
Hi Tim,
Best regards,
Minh
I totally forgot to mention, I recieve an network communication error whenever I'm trying to send a bug report, so I don't have any ID's. For some reason archicad thinks that I'm offline, however I do recieve an (.rep) file, which doesn't get send.
Thanks for the link, I see that I'm supposed to send this file to our local provider, I'll do this immediately.
Minh Nguyen
Graphisoft Alumni
Graphisoft Alumni
Hi Tim,
Yes, the REP file can be sent to your local partner for checking. Or, if you don't mind, you can drop me a private message and I will be very happy to check the crash report!
Thank you very much!
Best regards,
Minh
Minh Nguyen
GRAPHISOFT
