The vectorial engine doesn't use acceleration - it is ancient. So, the crash is surprising. Which versions of AC did you try (release/build and professional/student/etc)?
It looks like the Surface comes with the latest Windows 10 Pro update... 1909... which had some problems reported here:
https://archicad-talk.graphisoft.com/viewtopic.php?f=13&t=63322
I wonder if changing your Locale would resolve the issue, as it did for the posters in that thread?
Did you go into your Work Environment (before switching to Vectorial) - to the User Preference Schemes > Advanced Redraw Options and try disabling all options there - and turning acceleration to off? If that resolves it, try adding those things back gradually to track down the issue.
Hopefully either those settings, or changing our Locale, will resolve this for you.
One of the forum moderators
AC 27 USA and earlier • macOS Ventura 13.6.6, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
