Installation & update
Archicad not connecting with Grasshopper
Janja
Beginner
Hi! I am quite new to this workflow so I am having trouble figuring out how to solve the problem. The Grasshopper Connection in Archicad is just showing a warning "<no document connected>" , with connection status "waiting for grasshopper's response" and port number 19723. I have opened Rhino 7 as well as GH and the Archicad components are visible in GH. Not sure what the problem with the connection is as I don't have any more information about the error.
At the moment, AC connects to RH/G on the first session of AC you open. If you're trying to work in a different session, you can't change the port to establish the connection.
Think Like a Spec Writer
AC4.55 through 27 / USA AC27-4060 USA
Rhino 8 Mac
MacOS 14.2.1
Rhino 8 Mac
MacOS 14.2.1
Janja
Beginner
Thank you for your quick response! I must have opened the programs in the wrong order previously without noticing it... This time it did connect 🙂
