Setup & License forum
Arhicad 10 3-way keyplug on a Linux ?
Hi, is this possible ?
I have network licenc key for 3 comp.
is there any chance that i could connect the key to server,
witch is Linus SuSE Enterprise Server 9, x86-64
Cause the server is always switched on and on the network!
So that i could use any comp i want for ArhiCad,
so that i would not have to switch on the computer where shud be the keyplug!
I even found some drivers from the WIBU-Key homepage
but i don't know that do they work ?
and it also asked for account, that i don't have
Is there any help ?
3 REPLIES 3
There is a driver available on Wibu.com for "WIBU-KEY Runtime Kit. RPM package for RedHat 9, SuSE 9.x/10, Fedora." I don't know why they would have this available if it didn't work. Sounds like that is compatible with your server. I was able to download it without a username/password. I use there mac runtime kit without a hitch and there documentation seems pretty thorough. Not knowing your network environment my suggestion would be download and read the setup instructions and contact Wibu Systems with any uncertainties regarding your specific setup.
henrypootel
i wrote a little thing on setting it up a while back: http://archicad-talk.graphisoft.com/viewtopic.php?t=9187
I have had it running on a few redhat versions, fedora, ubuntu, and gentoo without problems. It is very easy to use, even if you aren't familiar with linux.
Josh Osborne - Central Innovation
HP Zbook Studio G4 - Windows 10 Pro, Intel i7 7820HQ, 32Gb RAM, Quadro M1200
OK, i found that later!
and one of my it spec found the right stuff for it!
tnx!
