Setup & License forum
Available Physical Memory
Hello everyone
How much memory (physical memory) are you guys have available and what is your RAM size.
for example I am running with 2GB of ram and have available 1.03GB when ArchiCAD and Plot Maker are open.
it seem to me that that is a lot of memory being used by two programs, so i would like to compare with you guys.
AC9 $ PM9
Thanks
2 REPLIES 2
Probably the most important factor in this is how large is the Project File you have opened. So these numbes can vary greatly.
My Archicad usually uses around 100-200 MB of memory, but a lot more if it is generating a large 3D Window model or rendering. Then it can use up all the memory of the system (I have 1 GB).
2x28" (2560x1440), WIN10 PRO ENG, AC20-AC26
Loving Archicad since 1995
Hi
I have 4gb ram and 1gb ram Fire ATI, I usually have about 2.4gb ram available and this is using a complex project. Bearing in mind this is in version 10 with no plotmaker.
Tom
