2022-11-17 09:28 AM
I just installed the Add-on (C4D) for Archicad 25.
On preview AC editions, I used to access the export settings under "interoperability" - "Cinema 4D export Settings". This enables to active "Surface" or "Element" based export.
This setting window is unavailable. Very Problematic.
Someone has a solution ?
Thanks
2022-11-17 12:03 PM - edited 2022-11-17 12:05 PM
ArchiCAD 25 5010 USA - Windows 10 Pro 64x - Dell 7720 64 GB 2400MHz ECC - Xeon E3 1535M v6 4.20GHz - (2) 1TB M.2 PCIe Class 50 SSD's - 17.3" UHD IPS (3840x2160) - Nvidia Quadro P5000 16GB GDDR5 - Maxwell Studio/Render 5.2.1.49- Multilight 2 - Adobe Acrobat Pro
2022-11-18 01:06 AM
Hello,
Thanks for your help.
No Settings were visible anywhere, until I SWITCHED OFF & BACK ON the Cinema Add-on. From then on the settings appeared under Design Extras.
YES !!
Thanks,
Best, Axel.
2022-11-18 09:17 AM - edited 2022-11-18 09:18 AM
Axil,
I have been wanting to demo a Maxon product but I know nothing about which one would be the best for what I am doing - which is mostly just Rendering of buildings and a few interior sceens modeled with Archicad 25. Is C4D just one program or do I need to choos some special version ? It looks like there are about 10 different products under the Render tab. Which one are you using ?
