Installation & update
CAN NOT CHANGE DIMENSION TYPE (ICON DISAPPEARED) V24.
please help me how to resolve this issue in the attached photo i cannot change dimension types in archicad 24
5 REPLIES 5
Minh Nguyen
Graphisoft Alumni
Graphisoft Alumni
Thank you for your question and I am very sorry about the issue!
Does restarting Archicad help in this case?
From the screenshot, it looks like there was something wrong with the Work Environment. I suggest performing a Preference Cleaning. Please follow the guide here: https://helpcenter.graphisoft.com/knowledgebase/25464/
Important: You may lose some of your modifications to the ARCHICAD interface, such as customized shortcuts, palette locations, etc. To avoid that, before deleting any files or folders: create a backup copy.
Please let me know if this helps with the issue!
Thank you very much!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
unfortunately I have restarted archicad and delete all files and folders as mentioned in the link but invain, I still have same issue
Belak1
I have same problem.
Minh Nguyen
Graphisoft Alumni
Graphisoft Alumni
Hi all,
Thank you for your report! Is there a way to reproduce the issue from scratch? Also, which language version are you using?
Best regards,
Minh
Minh Nguyen
GRAPHISOFT
Miha Nahtigal
Problem is not related to licenced AC24.
It's due to a pirated version and bad crack.
BIMquants.comBETA - Quantities and Costs Estimation with Archicad AddOn :: rushing to publish a beta preview
