Installation & update
CAN'T OPEN ANOTHER INSTANCE OF AC13 WITH OS 10.7.2 (LION)
dhaval7shah
I can't open another instance of AC13 using OS 10.7.2,
another instance starts opening then stucks.
does anybody have the same problem ?
Dhaval Shah
Upto AC 22
iMacs and MacBookPros: Mac OS X (10.6 to 10.12, Intel core 2 Quad to i5, i7, 8 GB to 16GB)
Win 10, AMD Opteron 6-Core x 2, 16GB, FirePro W4100 2GB
& ThinkPad E550
& i7, 8GB
4 REPLIES 4
Rod Jurich
Just installed 10.7.3, you show as 10.7.2.
No problem in opening a 2nd instance.
Try after you update.
Rod Jurich
AC4.55 - AC14 INT (4204) |  | OBJECTiVE |
Ben Cohen
its happening for me. I am on Lion 10.7.3 and I get a freeze when starting a new instance.
The work around is to launch a new instance using the default template and open the job from there.
Ben Cohen
Mac and PC
Archicad (Latest Version) aus
www.4DLibrary.com.au
dhaval7shah
I also installed 10.7.3 update, same problem continues.
Dhaval Shah
Upto AC 22
& ThinkPad E550
& i7, 8GB
No problem testing here with 10.7.3
I'm starting the new instance via File > New or File > Open with the checkbox to launch another instance.
Maybe your preference files are corrupted? Check the Wiki article on how to clear them out?
Karl
One of the forum moderators
AC 27 USA and earlier   •   macOS Ventura 13.6.6, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
