So what happens when you plug the key in and run License Manager without trying to sign-in?
This is what I see when I do it.
If you don't see anything then I am still thinking that it is a bad USB port (so try another one or try another machine if you can) or maybe something has gone bad with the key (it can happen).
If you have access to any other machine that has the Licence Manager software on it you can check it there.
Or see if you can just run Archicad using that key on another machine.
That will tell you if it is a problem with the key or not.
Do you have a support agreement with you local distributor?
That would be the best (and I would hope fastest) way to resolve this.
Or completely remove Archicad, codemeter and License manager.
Then reinstall Archicad and it will reinstall everything you need.
I am pretty sure the latest version of Archicad will install the License Manager as part of it (it definitely installs the codemeter drivers).
