Setup & License forum
COPY-PASTE PROBLEM FROM AC11 TO EXCEL
Hi all,
in ac11 i find this problem:
it is impossible to copy the drawing (into the area selection -fence-) and paste in excel.
That was possible in preview release.
Someone know why?
tanks.
Lorenzo
7 REPLIES 7
TomWaltz
What are you trying to copy? Text? Or walls and doors?
Tom Waltz
all: text, lines, objects from library etc..
thanks for answer.
TomWaltz
I'm not surprised. Excel does not have the drawing tools to handle Archicad elements. Text I could imagine working, but nothing else
Tom Waltz
But why on the preview release (AC6-AC7-AC8-AC9-C10) it works ?.
I've beta tested all versions since 7, including the release candidates (which is what I assume you mean by 'preview version') and have never seen the capability that you describe. Perhaps you are thinking of some other software?
Karl
One of the forum moderators   •   AC 26 USA and earlier   •   macOS Ventura 13.2.1, iMac Pro 10-Core, Radeon Pro Vega 64
tecnaspa wrote:
Hi all,
Someone know why?
tanks.
Lorenzo
I know what you mean.
I was having the same problem trying to paste in the "info preview" window to change the file icon.
See - http://archicad-talk.graphisoft.com/viewtopic.php?p=94485&highlight=#94485
There is now a Registry Key that you can alter (Windows this is - not sure about Macs).
You will need to find this key.
HKEY_CURRENT_USER\Software\Graphisoft\ArchiCAD\ArchiCAD 11.0.0 AUS R1\Input
Then set "Copy to picture also" to 1 (one).
Now you will be able to copy and paste to Excel or the preview window or where ever you want by selecting or marqueeing from Archicad.
Be cautious though - adjusting the registry is not recommended.
I believe GS added this key as a fix to the problem of Archicad sometimes freezing when you copy and paste.
Setting it to 1 (one) may cuase the freezing to occur occationally.
I haven't had sufficient time to test this yet but so far have had no issues.
I only found out about this last week though.
Versions 6.5 to 25
Dell Precision 3510 - i7 6820HQ @ 2.70GHz, 16GB RAM, AMD FirePro W5130M, Windows 10
Thank you very much, changing the KEY it works.
ps: when i say preview i means previous . Sorry.
If a will have problems i will know you.
Ciao
