https://helpcenter.graphisoft.com/knowledgebase/83528/
Here you can see some benchmark results for different graphic cards and a good explanation why a good CPU is important to make a GPU work as fast as it can. 1060 vs 1050Ti doesn't show much difference on smaller projects, but it grows larger for large ones. I'd go for the I7.
As you can see in my signature below I have an older workstation with a newer low end Quadro GPU.
This combination works without any problems even on larger projects. I guess any of your possible choices will do even better.
Archicad 4.55 - 25 | HP Z840 | 2× E5-2643 v4 | 64 GB RAM | Nvidia Quadro M5000 @ Windows 10 Pro x64
