Setup & License forum
Can't use Hardware Acceleration on my laptop
shrutiniwas
Hello guys, can you please help me out?
My HP laptop cannot detect "Hardware Acceleration" and only "Vectorial Engine" option is available as 3D engine. Below is the screenshot of the same for your reference. The problem here is that the surface finishes are not accurate. Otherwise AC25 is running. Will Intel graphics on my laptop support AC25?
HP Envy Touchsmart 15 notebook specs:
Intel Core i5 3230M @2.60 GHz
8GB Ram
Intel HD Graphics 4000
1TB Internal Hardisk
5 REPLIES 5
Your CPU is very old, it was introduced in 2013, which was 9 Intel CPU generations ago. The problem is that it support OpenGL 4.0 only:
https://www.cpu-world.com/CPUs/Core_i5/Intel-Core%20i5-3230M%20(PGA)%20Mobile%20processor.html
However, Archicad 25 requires a graphics card that support OpenGL 4.5:
https://graphisoft.com/resources-and-support/system-requirements
This is why you do not have Hardware Acceleration available because it requires a higher OpenGL version than the one your CPU supports.
Apparently, Archicad 24 needs only a graphics card that support OpenGL 4.0, which your CPU is capable of:
https://graphisoft.com/resources-and-support/system-requirements-24
So you should have Hardware Acceleration available in Archicad 24, but not in Archicad 25.
Get Archicad Tips at https://twitter.com/laszlonagy
AMD Ryzen 1700X CPU, 48 GB RAM, Nvidia GTX 1060 6GB, 500 GB NVMe SSD
2x28" (2560x1440), WIN10 PRO ENG, AC20-AC26
Loving Archicad since 1995
Kristopher Smith
Laszlo, what happens when the Hardware Acceleration is there one day and then gone the next? I am trying to help a client with this but I can't solve this issue. He hasn't changed his hardware and it is a bit older (4 years) but the acceleration was there and now its gone. Any ideas?
I am also having this problem. Were you able to solve it?
Maybe there has been an Operating System update or a video card driver update?
You may have to roll that back to what it was before.
You would think updates are good things, but not always, especially on older systems.
Versions 6.5 to 25
Dell Precision 3510 - i7 6820HQ @ 2.70GHz, 16GB RAM, AMD FirePro W5130M, Windows 10
mariemerian
Its speciality hardware like graphics cards and sound cards have been able to handle things better than your main CPU.If you want to try managing hardware acceleration for window 10 itself then you can try . Getting to your desktop give it a right click and select display setting once your setting down and click on graphic setting .click on acceleration setting if the option is not shown you need to restart your laptop.
